Are Bob Tech and SSQA the same?
   / Are Bob Tech and SSQA the same? #1
manac
CT
NH WM 70
New to the SSQA world. Looking at a grapple bucket that came off a Bobcat 943 for my NH WM 70.
Owner says it’s Bob Tech but that it won’t fit my SSQA. I‘ve seen a bit on the net saying that Bobcat developed the Bob Tech standard and the it was adopted by other manufacturers and sold as SSQA.
Thanks for your help.
   / Are Bob Tech and SSQA the same? #2
Thanks, I had read that first link. It was the only thing I had found so I wanted to make sure.
   / Are Bob Tech and SSQA the same? #4
Just measure across the top of the quick attach plate, there was a old bobcat standard that is about 39 in wide, anything newer should be around 45 in wide which is probably what it is, but I would double check.
Aaron Z
   / Are Bob Tech and SSQA the same? #5
Some dimensions:
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
New Hydraulic Oil Tank With Site Gauge and Filter (A47384)
New Hydraulic Oil...
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
(UNUSED) 2024 NEW HOLLAND C332 SKID STEER (A51242)
(UNUSED) 2024 NEW...
