Are block heaters needed?
   / Are block heaters needed? #1
dknarnd
Columbia County, PA
JD1010, JD B, TC40A (new)
Just curious if anyone uses a block heater on their tractor for the winter? Out of all the used ones I looked at only one had a heater.
   / Are block heaters needed? #2
I have two tractors - both diesel. The new one is a Kubota L3410. It does not have a block heater and has started fine down to -32F. Well, it does burble and smoke for a bit! The other is an old ford with glow plugs and a block heater. It really really likes the block heater to be on for 30-90 minutes prior to starting.
Oh, NEVER use starting fluid. Sure it will start the engine, but it can also destroy it in a heart beat if you use too much. The boundary between too much and just enough is thin -- real thin.
jb
   / Are block heaters needed? #3
I figure if you're going to use the tractor in the winter it's cheap insurance to have a plug-in heater of some type. We don't have one in our old Kubota, but we only use it in the summer. With our new Kubota, the dealer provided the block heater. It probably hardly needs it, but I like to plug it in for a while before starting it when it's really cold, just to make it easier on it. I bet our old one wouldn't start without a heater in the winter, it takes some coaxing even in the summer.
   / Are block heaters needed? #4
Is a block heater needed? No. Does it make starting in winter easier? Yes.
   / Are block heaters needed? #5
When cold temps arrive its given the heater will be plug in...I admit its little over doing it,but w/any little extra help in starting or keep frost out of the engine Iam for it.
   / Are block heaters needed? #6
Anyone ever use a 100 watt trouble light under the hood with a space blanket forming a tent to keep the heat in? Done is the barn out of the wind, of course.
Bob
   / Are block heaters needed? #7
Bob
Maybe drape a tarp over the tractor hanging down on each side past the engine with a light burning under the oil pan?? Heat rises, not sure you will gain much with a light bulb under the hood.
   / Are block heaters needed? #8
Agreed, you more accurately described what I was thinking. Sort of a "tent" of warm air.
Bob
   / Are block heaters needed? #9
dknarnd:
I did not have a block heater on my old Ford 1100 for 18 of the 20 years I had it. It never started easily in the winter until I installed a in-line coolant heater to the return radiator hose. It made a huge difference in starting when the temperature was below 32 (even more so when temperatures were in the single digits). I have a engine block heater on my NH TC29DA. I will plug it in for a couple of hours prior to starting. The colder it is the longer I pre-heat the tractor. I have had no trouble starting the tractor. I usually cover the engine cowling to trap in the heat during the warm up. I have used hair dryers and heat guns to pre-heat the diesel fuel lines and injectors in the past :(! Jay
   / Are block heaters needed? #10
I try bulb thingy but use 75 watt spot heat lamp on Farmall H...work okay but always cross my fingers....also try the oil stick heater,and never had any luck.
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
2017 GMC Sierra 1500 Elevation Crew Cab Pickup Truck (A51692)
2017 GMC Sierra...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
