dknarnd
Just curious if anyone uses a block heater on their tractor for the winter? Out of all the used ones I looked at only one had a heater.
Is a block heater needed? No. Does it make starting in winter easier? Yes.dknarnd said:Just curious if anyone uses a block heater on their tractor for the winter? Out of all the used ones I looked at only one had a heater.
Doc_Bob said:Anyone ever use a 100 watt trouble light under the hood with a space blanket forming a tent to keep the heat in? Done is the barn out of the wind, of course.
Bob
ovrszd said:Maybe drape a tarp over the tractor hanging down on each side past the engine with a light burning under the oil pan?? Heat rises, not sure you will gain much with a light bulb under the hood.
