Are backhoe subframes specific to the tractor or to the backhoe
   / Are backhoe subframes specific to the tractor or to the backhoe #1
penfrydd
New Holland 45
Hello all,
I've got a NH TC45 DA tractor. I've had it for about 10 years. Last year I managed to get an older Woods 750 backhoe. The only time I've ever had a 3ph backhoe was an ancient Long on a Ford 4000, without a subframe. Yes, it was too heavy for the tractor, but that tractor was way more beefy than this TC45. From what I've read, I need a subframe. As the title suggests, I want to know if the subframe is specific to the tractor, or to the backhoe, or to the combination.
Thanks
Thom
Colrain, MA
   / Are backhoe subframes specific to the tractor or to the backhoe #2
Hopefully others will replay also, but I have to believe its a combination of both the backhoe and the tractor.
I have a TC33D with a backhoe and would not doubt that its subframe might fit a TC35 as well but I would highly doubt it would fit your TC45 as I think your 45 is a frame size bigger than my 33.
   / Are backhoe subframes specific to the tractor or to the backhoe #3
When I bought a Kubota backhoe, I needed a specific subframe that was only for my model of tractor and backhoe.
   / Are backhoe subframes specific to the tractor or to the backhoe #4
There's a specification manual on Woods' website where you can drill down to your tractor and it will show you the proper subframe for their backhoe. As I recall, it was somewhat hard to locate but it's there.
I'm still trying to find a subframe for my Kubota B2910. Mine calls for the Woods part #1005650. The subframe is specific to both the tractor and backhoe.
   / Are backhoe subframes specific to the tractor or to the backhoe #5
I just spent some time on Woods' website and I can't find the link that lets you look up the subframes. I recall that it was well hidden the last time I needed it, but I can't swear that it's even there. If you want to pursue that, and you don't find it, might be best to call Woods or have a dealer look up the correct subframe.
Good luck. This can be a frustrating item to find as many of them are no longer in production or in stock anywhere.
   / Are backhoe subframes specific to the tractor or to the backhoe #6
You can possibly start selecting a few different models to see if they are compatible:
The B75 is not according to this link, look in the table for Tractor Compatibility, the BH75 is for a TC33, TC 35 & TC40 :
   / Are backhoe subframes specific to the tractor or to the backhoe #7
I'm pretty sure that Woods makes a 4 point quick attach subframe to fit the TC35/40/45 DA series of tractors.
I bought one of their models to put on my TC33D (the subframe was made to fit the TC33DA, but my local NH/Woods dealer made that happy discover that it would also fit the earlier model TC33D). I bought a used Woods 7500 that was set up for 3 Pt Hitch mount. I just unbolted a couple of the 3PH mating parts from the backhoe and bolted on the mating parts for the 4 point quick hitch, and was ready to do.
It works really well. The subframe stays on the tractor all the time. When I'm in practice, I can mount the backhoe in less than 10 minutes. (It's been a couple of years since I used it, so I'm sure it would take me longer now.)
I'm not sure how well it will fit with the Woods 750 backhoe, but its worth asking. (NOTE: back when I was considering trading up to a larger tractor, I asked about taking my back hoe with me. If I recall what my dealer said correctly, Woods made two different subframes for a TC40DA. One would fit the 7500 and another would fit their next size larger backhoe - I think it was a Woods 8500?? They suggested I go up to the larger backhoe, as it would be a better match to the TC40DA. I never upgraded to the larger tractor, so not sure how the 7500 would have worked out on it.)
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56438)
Midwestern...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
