Are aluminum fittings okay in a 1500psi hydraulic system?
   / Are aluminum fittings okay in a 1500psi hydraulic system? #1
matt2491
Massachusetts
1977 Sears 14/6
I am putting together a relatively simple hydraulics system. The system will be powered from a GM Type II automotive power steering pump that generates no more than 1500psi. Are aluminum adapters & fittings okay to use at this pressure? Some of the adapters I need come from the automotive world and are only available in aluminum.
   / Are aluminum fittings okay in a 1500psi hydraulic system? #2
If they are rated for that kind of pressure, they are OK.
In the automotive world, they often use "AN" fittings, which fit JIC fittings in the hydraulic world.
I use a power steering vane pump and a one-spool hyd valve to power my hyd dump bed on my Suzuki
Samurai. I get only 1400 psi, and may modify to get 1600. One of my fittings is type "AN".
Thanks for your reply.
What if they have no rating? Risky to use?
For example, I'd really like to use this -8 to dual -6 Y-adapter made by Vibrant:
There is no published pressure rating, but it would fit perfectly in my system to split a pressure line feeding two cylinders mounted next to each other. Just wondering if I'm asking for trouble.
   / Are aluminum fittings okay in a 1500psi hydraulic system? #4
I'd use it...as long as it's machined and not cast-which it looks like it is (machined that is).
   / Are aluminum fittings okay in a 1500psi hydraulic system? #5
I'd be using it also. If you are worried about a possible burst, cover it with a heavy canvas and zip tie it around the fitting. May not look the best but it'll prevent a spray of fluid getting somebody.........Mike
   / Are aluminum fittings okay in a 1500psi hydraulic system? #6
Aviation uses a lot of aluminum fittings but then there are many grades of aluminum*.
Two standards exist, the original was T series while current nomenclatures is NAS.
*T1 - T6 with T1 being soft and T6 very stiff and actually quite brittle but very strong.
T6 machines nicely but don't try to form it on a brake.
I'll give it a shot! Thanks for everyone's input.
LOT IDENTIFIER 13 (A53084)
LOT IDENTIFIER 13...
2021 JOHN DEERE CP690 LOT IDENTIFIER 204 (A53084)
2021 JOHN DEERE...
2007 CHEVROLET SILVERADO K150 CREW CAB TRUCK (A51247)
2007 CHEVROLET...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
20703 (A51694)
20703 (A51694)
1996 Timpte 46ft Hopper (A53473)
1996 Timpte 46ft...
