sailorman
Platinum Member
I don 't know if I missed this question, but how do you determine which eye is dominate ?
Hold your thumb at arms length and focus on a spot on the wall. Close your right eye, see if your thumb appears to move. If it does you are right eye dominant. If it doesn't move you are left eye dominant.
Extend your arms in front of you with your palms facing away.
Bring your hands together, forming a small hole by crossing the thumbs and fore fingers.
Choose a small object about 15-20 feet away from you. With both eyes open, focus on the object as you look through the small hole.
Close one eye and then the other. When you close one eye, the object will be stationary. When you close the other eye, the object should disappear from the hole or jump to one side.
If the object does not move when you cover one eye, then that eye is dominant. The eye that sees the object and does not move is the dominant eye.
Tips:
Hand-dominance does not always correlate with eye-dominance.
Most people automatically use their dominant eye when looking through a camera eyehole or a telescope.
What You Need:
Your arms and hands
A target about 15-20 feet away
What if your thumb is blurry when you focus past it at the wall with both eyes open, but moves to the left and right when you alternate which eye is closed
In some people (ambidextrous for instance) the dominance is often undetectable with simple tests......I've heard in rare cases a person may not have a dominant eye...
hmm.. depending on which way my head is tilted, either slightly right or left, I can make the test results swap. IE. object is seen with one eye, jumps with the other, and then cock head a few degrees, and do the same .
or, move the hands an inch or 2 right or left and there are 2 focal regions I can see the object. each region seems to ID a different eye.. etc.
Stores like Cabela's, Sports Authority or Academy Sports do a good job of fitting you to a bow and have some lower cost bows available.
Provided you have some of these stores close by.
