Archery or Bowhunters....help
/ Archery or Bowhunters....help #21
Boeing,
I have used a "verifier" on my compound bow for roughly 8 years. You know you need one when your sight pins start to blur or, the colors on the pins tend to "wash" together. Any good archery shop will have them. They have a handheld apparatus that you will use to determine which verifier is right for your eye. Once you have selected a particular lens that clears up your pins, you will have to put a new threaded peep into string that accepts the verifier lens. Be aware that their are roughly 6 different verifier "powers", so look through each one before you choose. Also, a verifier is meant to sharpen your pins, it does nothing for the target you are shooting at. If anything, in my case, it very slightly blurs the target, barely perceivable though. If it was not for the verifier, I could not use pin sights anymore and I probably would have stopped shooting vertical bows. When I tried my first verifier, I started to dance the jig, because of how clear my pins were again.... Good luck.
BTW, claifiers are used in conjunction with bow scopes/optics, would not be applicable to your situation.
/ Archery or Bowhunters....help #22
I also went with a verifier and it worked great.
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2021 NM 2HD-18 18in. Bucket w/ Teeth Excavator Attachment (A66734)
2021 NM 2HD-18...
953D GP Bucket (A68134)
953D GP Bucket...
2017 Crane Carrier Co. T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
