Arborvitaes
   / Arborvitaes #1
TCBoomer
Platinum Member
CT
New Holland TC24DA
Greetings everyone!
I've started a HUGE project after plenty of research. Yet I still have unanswered questions and hope there might be some here that can help with answering. It involves trimming and thinning a 900' hedge consisting of about 300 Arborvitaes. I should point out that I had zero experience with this task prior to starting.
A third of these trees are mature at about 20' tall, planted in 1996. The remaining are about 8-9' tall with a few approaching 12' and these were planted 4 years ago. All of them are healthy with the exception of the mature ones growing wild and getting too big for their place. None have ever been trimmed with the exception of dead or broken branches. Early on I did inquire about trimming them and was told don't bother...something I now regret!
Here's a few questions for starters...
1) I removed about 20-25 cubic yards of dead needles from under the mature ones. The debris was about 6-8"+ deep and as a result a number of the lower branches were buried. Some even rooted themselves. I freed up what I could by clipping, but there are still some that remain partially buried. By that I mean the branch is exposed now but still firmly rooted underneath it. Some even re-sprouted about a foot away from where it entered the ground. Looks like a mini propagation farm under there! Should I leave as be or cut the branch or?
2) Pros & cons with cutting the tops of the mature ones about 2-3'. The purpose being to open the canopy to sunlight as well as even the tops out. My goal, understanding that it will take a few years, is to cut back the base growth from it's current width of about 6-8' back to 4-6'. Yes the insides of these mature ones are bare due to no sunlight and air flow. So that limits my cutting back right now.
3) Right now my approach to thinning is cutting the vertical growth and oddball branches with excessive growth. I'm also taking a stab at shaping them and leaving selective 'holes' for sunlight to get to the insides....but that's not as easy as it appears:confused2: Any tips or tricks of the trade for this procedure would be GREATLY appreciated!
Here's a few pics of what these trees look like prior to starting. You might say they look great but trust me, up close they need help. I'm confident I'll get it done one way or another. I'm down to my last day of vacation...been off the last week...so I'm out the door and back at it after I post this. I'll check back in later.
Thanks in advance for any info or links etc that might assist me.
   / Arborvitaes #2
I have no clue for the care of them. I just want to say, those pictures are
amazing.
Now, that is a privacy fence!
   / Arborvitaes #3
Greetings everyone!
I wish that was our hedge.
   / Arborvitaes #4
Don't take off too much and make sure they are wider at the bottom than at the top. Just a bit, the leggy bits like you have said already.
   / Arborvitaes #5
I do know what you mean about dead needles -- they can really build up under a large arborvitae. I remember to clear ours out every couple years, and the amount of dead needles I shake/rake out is mind boggling. You have to wonder if the tree is adapted to that somehow.
They are nice trees. I have never attempted to trim or prune them back, but would caution not to remove more than about 15% of the tree. Find out when the best time is. Myself, I would not attempt any pruning this time of year where I live.
Good luck!
   / Arborvitaes #6
Those look like Thuja arborvitae, especially if they've grown that large. If so I have the same trees around my property, I talked to the place we buy them from and they said you can trim anytime. I have the hedge in front of our house trimmed down to 4' so we can see over it. The others have been left untrimmed and are probably as tall as yours. I found that when you trim they do turn brown, often times beyond the region where you pruned. But they recover and green back up and begin growing like weeds pretty quick. My experience with other evergreens is to only prune when they're dormant, I guess to be safe I'd recommend that unless you're really sure what species they are. I also have some along a lane that I use a hedgeclipper on to keep the width down. They take trimming very well and happily grow right back so you never run out of things to do.
   / Arborvitaes #7
Sorry, no expertise here. I just wanted to chime in and say that you have one beautiful lawn and border. Wow.
   / Arborvitaes #8
I have had Aborvitaes in southern New England as well and I was able to trim the leaders off which in turn made them fuller. I though it was better to trim in the fall, but this advise is worth what you paid for it. ;)
There was a house down the road that had 12'ers and he butchered them to down around 6' to where there was just a small amount of branches. I thought he killed them but lo and behold they grew back in just a few years.
Nice lawn as well.:drink:
   / Arborvitaes #9
Generic pruining advice is to prune when dormant and never remove more than a third of the trees living branches.
That said im a forester not an arborist. But the third rule is a major one.
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A53422)
2021 Chevrolet...
UNUSED WOLVERINE DB-15-84W 84" HYD ANGLE BLADE (A54757)
UNUSED WOLVERINE...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2014 Ford Escape (A50324)
2014 Ford Escape...
RING 3 STARTS HERE @ 9:30 AM (A54757)
RING 3 STARTS HERE...
