AR15 Sling Advice
   / AR15 Sling Advice #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I bought a Mossber AR15 a few months ago and am looking for sling advice. This had the M-lock fore end on it but I think I just want a 1 point sling. I also wonder how you hook this up. A lot of the pics seem to show a bracket installed between the buffer tube and the receiver that has a hole in it for the sling to hook into. How do you install this bracket? I can find all kind of info on slings but none that really show how to hook it up to the rifle.
   / AR15 Sling Advice #4
Make sure you stake the castle nut when you finish.
   / AR15 Sling Advice
Thanks for the links. I wasn't quite searching for the right thing in google and didn't get the results I wanted.
   / AR15 Sling Advice #7
How do you unstake a castle nut?
Pull hard with your armours wrench (spanner?:laughing:) and tap the end with you plastic hammer
   / AR15 Sling Advice #8
I did and it still won't budge. Even broke one mounting block.
   / AR15 Sling Advice #9
Take your dremel with a very thin slitting wheel and relieve as much of the staked deformed metal as you safely can. Then put on your armours wrench/spanner, and put some down pressure and hit the end of the wrench with your plastic hammer to offer some impact. Impact will always loosen things that pressure wont.
   / AR15 Sling Advice #10
Thanks James, I will try that.
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND68FDGH1824 (A54865)
2015 Freightliner...
Electric Mobility Scooter (A51694)
Electric Mobility...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
Case-IH 370 Steiger (A53314)
Case-IH 370...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
