AR15 Sling Advice
   / AR15 Sling Advice #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I bought a Mossber AR15 a few months ago and am looking for sling advice. This had the M-lock fore end on it but I think I just want a 1 point sling. I also wonder how you hook this up. A lot of the pics seem to show a bracket installed between the buffer tube and the receiver that has a hole in it for the sling to hook into. How do you install this bracket? I can find all kind of info on slings but none that really show how to hook it up to the rifle.
   / AR15 Sling Advice #4
Make sure you stake the castle nut when you finish.
   / AR15 Sling Advice
Thanks for the links. I wasn't quite searching for the right thing in google and didn't get the results I wanted.
   / AR15 Sling Advice #7
How do you unstake a castle nut?
Pull hard with your armours wrench (spanner?:laughing:) and tap the end with you plastic hammer
   / AR15 Sling Advice #8
I did and it still won't budge. Even broke one mounting block.
   / AR15 Sling Advice #9
Take your dremel with a very thin slitting wheel and relieve as much of the staked deformed metal as you safely can. Then put on your armours wrench/spanner, and put some down pressure and hit the end of the wrench with your plastic hammer to offer some impact. Impact will always loosen things that pressure wont.
   / AR15 Sling Advice #10
Thanks James, I will try that.
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
Krause Dominator 4850-18ft (A55302)
Krause Dominator...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A54865)
New/Unused AGT...
