Chains Aquiline chains: How are they?
   / Aquiline chains: How are they? #11
I installed Aquilines yesterday on my Kubota B7800. Been frustrated all winter so far with the 'standard' chains not being effective on ice.
The Aquilines (not Talon) made a world of difference. They were expensive but totally worth it. My only concern is the 't' link used to connect the ends together. I hope they stay on.
I lost one of the links Norse supplies with their chains, it sounds like the same kind of coupler. They also send a C-shaped open chain link with a split pin that drives in to close the link. I put that in place of the T-link that went missing. So far that's stayed put.
Chilly
   / Aquiline chains: How are they? #12
Thanks for telling me this! I hadn't figured out what to do with the C links. ONce installed, can you move the pin to uninstall the link to take the chains off?
   / Aquiline chains: How are they? #14
Now THAT is a good question :) Mine are loose enough that I can roll the chain up high enough to get a pin punch in there. I think.
Chilly
   / Aquiline chains: How are they? #15
Chilly
On my Trygg's I painted the roll pin in the C links with never-sieze, worked it back and forth before I closed it up so I can get it back apart next time. I always do the same with clevises. After running them in salt during the winter they can be a pita to get apart w/o never-sieze.
   / Aquiline chains: How are they? #16
i know i'm beating a dead horse here but i never did understand why folks buy a tractor with industial tires on them if they don't give very good traction in mud and general farming unless they are being used in an industrial setting. i have ag tires on my kioti, been in many sloppy, slick muddy situations and never once been hung up, never needed chains. why put expensive tires on a machine that are generally useless and that you'll have to buy chains to go anywhere. i can see chains on a 2 wheel drive but on a 4 wheel drive tractor i can't, sounds like somebody needs some ballast added.
   / Aquiline chains: How are they? #17
Chains help. The most extreme us of AG tires I have ever seen is on log skidders. I've never seen a log skidder, summer or winter, without chains on it.
Because:
1) the dealer makes more money;
2) they add a lot of ballast with the fluid which gives more more to the dealer;
3) they help with the loader that also gives more money to the dealer.
   / Aquiline chains: How are they? #19
When you're on snow covered ice, it doesn't much matter whether the tires are R4's or R1's. Rubber on ice is still rubber on ice.
Having said that, I agree that the R1 is the more practical tire for traditional tractor use. Quite a few of us here don't use tractors in the traditional (farming and logging) style.
I'm one of those who need R1's (AG), so I got R1's when I got the tractor. I was lucky enough to buy new, so I had the choice.
Quite a few people buy used. If my used (new to me) tractor came with R4's in good shape, well, it's going to get those worn out before I dig into my wallet any further for a set of new AG's and rims. Or, until I get tired of getting stuck more than I should :)
Chilly
   / Aquiline chains: How are they? #20
I understand where you're coming from on the R-4's. I have never owned any tractors with them, all of ours have r-1's. I travel a lot of pavement and still like the r-1's, much more versitile. My r-1's on the rear of my 4150 have over 1700 hours on them, 60% worn and will dry rot before I ever where them out. Yet I drive it hundreds of miles on pavement a year.
As for chains, if you go where I have to go you don't do it w/o chains. All our tractors that we run have chains, Kubota 6800, 4150, Ford 9n, 2n, 600, 5000 all have chains. W/o them you aren't going to push snow or get anywhere.
2006 JOHN DEERE 650J XLT CRAWLER DOZER (A52707)
2006 JOHN DEERE...
2013 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2013 FREIGHTLINER...
2020 CHEVROLET SILVERADO(INOPERABLE) (A55745)
2020 CHEVROLET...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
Booster Cables (A55852)
Booster Cables...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
