Anything special about the coolant on an L3200?
   / Anything special about the coolant on an L3200? #1
Madison, Ga
Kubota L3200HST with LA524 Loader, Quick Connect; Loaded R4 Tires
I was going to change mine out and put in a 50-50 mix of Prestone Extended Life coolant. I know my Powerstroke takes a special coolant. Thought I'd better check on my L3200 before I did it.
   / Anything special about the coolant on an L3200? #3
Check the manual, it specifies what to use. If in doubt, buy it from your dealer. I was expecting Kubota branded AF when I got mine, it was something different, but still good stuff.
   / Anything special about the coolant on an L3200? #4
Your 7.3 powerstroke requires SCA additives because of the cylinder wall breakdown.
I don't think you need to worry about this on your tractor.
   / Anything special about the coolant on an L3200? #5
Use conventional "green" ethelyne glycol coolant-think 1975.
Can almost be a little hard to find these days with all those universal,extended life formulas out there.
A dealer or a good auto parts store will have it.
Unless your coolant is filthy and needs flushing,a drain and refill with a 50/50 mix of green and distilled water would be a great choice-just what your Kubota comes with.
Good Luck!
   / Anything special about the coolant on an L3200? #6
Anything from Wal-Mart is fine and is what the owner's manual calls for.
16ft Trailer (A50322)
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
2021 Exmark Lazer Z 60in Zero Turn Mower (A49461)
2021 Exmark Lazer...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
New Holland B95 Backhoe (A50490)
New Holland B95...
