Anything special about the coolant on an L3200?
   / Anything special about the coolant on an L3200? #1
Madison, Ga
Kubota L3200HST with LA524 Loader, Quick Connect; Loaded R4 Tires
I was going to change mine out and put in a 50-50 mix of Prestone Extended Life coolant. I know my Powerstroke takes a special coolant. Thought I'd better check on my L3200 before I did it.
   / Anything special about the coolant on an L3200? #3
Check the manual, it specifies what to use. If in doubt, buy it from your dealer. I was expecting Kubota branded AF when I got mine, it was something different, but still good stuff.
   / Anything special about the coolant on an L3200? #4
Your 7.3 powerstroke requires SCA additives because of the cylinder wall breakdown.
I don't think you need to worry about this on your tractor.
   / Anything special about the coolant on an L3200? #5
Use conventional "green" ethelyne glycol coolant-think 1975.
Can almost be a little hard to find these days with all those universal,extended life formulas out there.
A dealer or a good auto parts store will have it.
Unless your coolant is filthy and needs flushing,a drain and refill with a 50/50 mix of green and distilled water would be a great choice-just what your Kubota comes with.
Good Luck!
   / Anything special about the coolant on an L3200? #6
Anything from Wal-Mart is fine and is what the owner's manual calls for.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
Delta Consolidated Fuel Tank 48000 (A51039)
Delta Consolidated...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
