Anything but a hydro...why?
   / Anything but a hydro...why? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
So I've been looking for a second tractor, and I am considering one that has a mechanical shuttle transmission. I really want a hydro, but I'm just going to use it infrequently for basic maintenance tasks and to carry a backhoe, so it doesn't really matter. I guess I'd have to get it really cheap, although I'm on the fence whether or not to even go look at it.
I've never driven a mechanical shuttle - from what I can gather, it's basically a straight gear tranny that goes in either direction - clutch required to do everything? There is always the worry of ending up with a burnt clutch too - is replacing a clutch plate a big deal? They say that shuttle transmissions are great for loader work, but I can't imagine that doing any amount of loader work would be practical for a clutched machine, regardless of having a shuttle reverser.
OTOH, my current tractor (Kubota L4200) is a glide-shift, or clutchless synchronized shuttle, and I do love my tractor, but it can get downright confusing at times - especially while running my snowblower in parking areas (lots of back and forth and snow re-direction) - shifting gears, chopping and stomping the speed pedal, working the shuttle shift, steering (backwards), and working the dual hydraulic chute controls all simultaneously...I'm a drummer and have pretty good independence, but I don't think I could work a clutch pedal into the mix on top of all of that. I surely believe that a hydro is the right tool for that job. Or any job?
Then I have to wonder, why aren't all CUTs hydrostatic? I don't think too many people pull plows on 100 acre fields with 4WD CUTs, so what common CUT task would actually be made easier or be done better with a gear tractor, and why would anyone want one?
JayC
   / Anything but a hydro...why? #2
Don't know about anybody else Jay, but I went with gear because I'm old school, it's what I grew up with and it's what I know how to work on.
Heck, the truck I own now is my first auto.
Hydro trannys baffle me.
   / Anything but a hydro...why? #3
I have a B3200HST. It is a life saver. I had a Allis-Chalmers geared that had to have a directional valve pushed in when you used the FEL or BB. In for one out for the other. That was a killer especially with a back problem and arthritis in the left hip.
I grew up driving any one of 8 to 10 tractors most geared for working the ground with big equipment and long hours.
   / Anything but a hydro...why? #4
Same here.
   / Anything but a hydro...why? #5
I have had a geared tractor for five years and did a lot of loader work. I recently purchased a B3200HST which is much better for loader work hands down. A lot of clutching and shifting with the geared tractor.
   / Anything but a hydro...why? #6
Yeah, I was "old school" until I got "old". I grew up farming and ran geared units most of my life. I now have tractors I can no longer drive due to bad hip, knee, back...
I still drive a geared tractor, M8540, but it is hydro shuttle.
As to burning a clutch, we have never burned one out though the one on our 54 NAA is probably getting close. We did a LOT of loader work as well as direction changes mowing hills for 12 years with a synchro shuttle on our CX80 and no problems.
I know of no common CUT task made "easier" with gears.
   / Anything but a hydro...why? #7
I have more hours in gear tractors than Hydro, but it Hydro for me from now on for the normal CUT tasks. I do mostly landscaping/dirt /loader work. When you work all day with a loader, with gear my left knee and leg was barely able to get off a gear tractor and walk to the house. I am getting old too.
Maybe this will help understanding the transmission types.
http://www.tractorsmart.com/main/Tractor Transmission Types.htm
James K0UA
   / Anything but a hydro...why? #8
The disadvantage of hydro is it robs a little power. Personally, I'd say if you are running an implement that needs 25 PTO hp, get a tractor that's got 30 or more. If hydro vs gear makes enough difference (.5hp in my model) between being able to run an implement or not, you're cutting it too close anyway.
I wouldn't have anything but a hydro for backhoe work. No you shouldn't, but it's very nice to simply reach to the front of the tractor from the bh seat, raise the FEL, use a stick to push the hydro pedal and move ahead to keep digging. Getting off the bh, jumping off the tractor, moving and reversing the process would be exhausting if you were digging a few hundred feet of trench.
   / Anything but a hydro...why? #9
I am an HST advocate; love them. But, I went with shuttle shift on my CUT because it allowed me to put more power to ground. I think this is only an issue when the tractor is marginal on power for it's weight with an HST. Gaining back a few HP is significant at the lower end of the hp spectrum. I also saved a good bit of money. To get comparable power from an HST I would have had to move up a notch in HP. That price difference, coupled with the HST upgrade, meant about $2500 more for the tractor. I didn't need HST bad enough to justify it.
Now, after 6 years of using shuttle to move well over 1000 tons of materials, I don't really see the HST as that much better at loader work. Less tiring, yes. But operating the clutch has never seemed to be that big of a deal for me. And has pointed out by others, sometimes you wish you had about dozen arms and legs to operate all the things you need to at one time. Here, the HST is much easier.
In some configurations, using split brakes is not practical on HST's. The value here, depends on how much you use this feature.
At the end of the day, if you can afford (and are willing to pay) the models with adequate HP in HST, HST is the better choice. I could neither afford, nor was I willing to pay to up-charge. And I love my Shuttle beast.
   / Anything but a hydro...why? #10
I bought geared because I like them, less to go wrong, less maintenance and cheaper maintenance. I used mine several days building a pond which was 10 hours a day back and forth clutching and changing forward and reverse. I was less tired doing that than 30 minutes on my brother in laws hydro New Holland. Maybe it was just the position that I had to hold my foot and leg to work the pedals on his, but I could hardly get off the tractor my leg was so cramped up. I prefer gear and a clutch that I only have to touch when I want to stop and or change gears rather than a constant foot pressure on a hydro-pedal. Select the gear, Set the throttle at the speed you need and go, clutch, shift shuttle shift lever and go. THe power shift gear models are best of all worlds to my notion. You can change gears and directions without clutching and no power robbing hydro or hydro whine. You can set the throttle and shift away or use the foot throttle and throttle down for reversing. Is it better than hydro, up to the individual . Is hydro easier, to me not really, you just transfer the motion of clutch with left foot when needing to shift to constantly having the right foot moving between F and R and speed adjustment.
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2019 Grove TMS500-2 40T Crane (A60460)
2019 Grove...
Toro TRX-20 Walk Behind Trencher (A57453)
Toro TRX-20 Walk...
NON RUNNING 2019 Ford F-550 Truck, VIN # 1FDUF5HT1KEC13083 (A57453)
NON RUNNING 2019...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
