3-Point Hitch Anyone using Pat's Hitch with a tiller on your GC series?
   / Anyone using Pat's Hitch with a tiller on your GC series? #1
rossn
Denver, CO
Massey Ferguson GC1705
Is anyone using Pat's Hitch with a tiller on your GC series?
I've heard that there is some play in the attachments, when mounted to Pat's, and that some implements such as tillers may not be as good on a quick hitch. Also, have heard that the extra 4" on a SCUT can be problematic, but haven't been able to find any additional information on this.
   / Anyone using Pat's Hitch with a tiller on your GC series? #2
I use a quick hitch on my GC2610 for a tiller and box blade as it is easier to manhandle the lighter hitch onto the tractor. It works fine for me.
   / Anyone using Pat's Hitch with a tiller on your GC series? #3
The extra 4" may require you to get a different PTO drive line cut to the extra length. I'd think that Pat's would work okay. My Quich Hitch works just fine on my set up viz, my Kubota B2620 with a 50 inch LandPride tiller...and I have done quite a bit of garden tilling the past few years.
Thanks. Was thinking that since I'm buying the tiller this week, it would make sense to do the quick hitch at the same time, so as to not cut the driveshaft too short.
   / Anyone using Pat's Hitch with a tiller on your GC series? #5
If you find the PTO shaft is too short after adding a quick hitch, they do make PTO extenders, usually ~$20.
   / Anyone using Pat's Hitch with a tiller on your GC series? #6
The instructions for installing the tiller were really poor and being a newbie I did some minor damage to the u-joints. Nothing needed replacing and all works well but be carefull to check for u-joint clearance at both ends of your lift travel.
AYLEID HOSE REEL, SPRINKLER (A51244)
AYLEID HOSE REEL...
18003 (A51691)
18003 (A51691)
2018 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2001 Dodge Ram Wagon Passenger Van (A51692)
2001 Dodge Ram...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
