Mowing Anyone using an 84" finish mower on a B2920?
   / Anyone using an 84" finish mower on a B2920? #1
Merrillgna
Galloway, ohio
Kubota
Im looking to step up to the woods PRD8400 finish mower. It says the rating of the tractor needs to be 25-40HP. With the B2920 rated at 29HP do you think it could handle it mowing 5 flat acres of your average type grass or would it constantly be overworking? Curious if anyone is using a mower that big on the B2920. Thanks.
   / Anyone using an 84" finish mower on a B2920? #2
Overloading a PTO driveline is never a good idea, especially on a light weight transmission housing... It can get rather expensive.
Even an occasional overload is not going to be helpful .
   / Anyone using an 84" finish mower on a B2920? #3
I am not specifically familiar with the Orange tractors, but have the opinion they are a quality well built unit, and therefore you should be able to utilize all 29 HP if you want to, even at the rear PTO. I have the Green equipment and mow with 72" finish decks in very tall grass (mow about 20 acres, five times a year, grass height varies from one to two feet and thick / dense in certain areas). I mow at ground speeds that typically engage all 27 HP or 32 HP respectively (JD zero turn 777 and JD 2032R). They are both 72" MMM and not rear PTO versions. If you are mowing a 'lawn' on a regular basis with an 84" finish deck, in grass 4 to 6 inches in height and at ground speeds of 4 to 6 mph, I don't think you would be pressing the limits at all, regarding HP consumption and excess load on any power train component. Happy cutting.
   / Anyone using an 84" finish mower on a B2920? #4
Tractor HP or PTO HP? I think the 2920 is only 21-22 HP at the PTO.
Probably would work for easy cutting. But in borderline cases, even 29HP will run out pretty quick.
Thanks guys. I also emailed woods equipment and they said it will handle it just fine as long as I don't cut when it's real tall. I was just curious if any one is actually using a finish mower that size on the B2920
   / Anyone using an 84" finish mower on a B2920? #6
I'm going to say it's way too big for your tractor. You are low on PTO power and tractor weight. A mower that big will really make the front end light and will swing the tractor around on turns and hills. A neighbor has that same mower and uses it on a M4700 and it seems to be a good match.
   / Anyone using an 84" finish mower on a B2920? #7
You say the area is FLAT. Because if it's not, you arn't going to get a very good cut with a seven foot mower. It's the reason why nothing really cuts as nicly as say a 22 inch push mower. It just follows the terrain better. My bigger mowers all have seperate wings.
   / Anyone using an 84" finish mower on a B2920? #8
I'm running a 6' rear discharge finishing mower on my L3800. It feels like HP and size are balanced, so I can move along and get the acreage done. If I had to slow down I might just not have the time then I'd let it go and wait til the brush hog was more useful. I'm fairly certain that 84" and 29hp will force you to slow down.
But on second thought if you get the 84" mower you could then justify getting a bigger tractor. :D
   / Anyone using an 84" finish mower on a B2920? #9
Looks like no one has an actual experience answer for you which can possibly be an answer itself or taken as a "No, no one has done it" answer.
I can give a close actual experience answer and then you can go from there. I owned a B7800 which is the next step up in HP and I think maybe a bit more in size so you do the difference factoring.
I had a 6' RFM red French brand lightweight mower on my B7800 and on my field converted to yard by just mowing the red rfm kept breaking. I also have some fairly steep hillside with some flat front yared with gullies and rocks. Never had any power or lack of power issues. Traded the lightweight 6' tearing up mower to a Landpride 6' RFM (tank in weight and thickness of metal) probably equal to a Woods in weight. With the Landpride on the back of the B7800 I never had any power issues with mowing or climbing the steep hill side but at the bottom of the hill when I made my turn the mower would swing the B7800 (with FEL always on) around which surprised me the first and maybe second time but it just became the way I made my turns at the bottom of the hill from then on with no problem or concerns. I also was never the full throttle and still mostly am not now kind of person. Meaning I never used full throttle on the B7800 pulling the 6' Landpride mower
I traded the B7800 to a L3240 (twice the tractor weight but same HP as the B7800) and the mower had no impact on turning the tractor but the tractor would really slow down as I was nearing the crest of the hill which shows how much impact tractor weight has on the HP usage.
I know I didn't answer you direct question as no one else did but I give you some actual experience with near to your situation and you draw your own conclusions.
I personally believe your tractor may turn the blades and pull the weight under flat and ideal grass levels on the bigger deck but I believe you will be stretching the tractor to or beyond it's maximum capacity and if you incur some gullies or hills I believe you'll know if you have exceeded its capacities.
Good luck and if you go for it you can be the guy that steps forward and tells others of your experience and how well or how not quite so well it worked out for you.:thumbsup:
   / Anyone using an 84" finish mower on a B2920? #10
I'd take a shot at a 72" but not 84!
2006 DRAGON ACID TRAILER (A45333)
2006 DRAGON ACID...
2019 KENWORTH T880 (A45046)
2019 KENWORTH T880...
2015 Ford Transit Connect XL Cargo Van (A42742)
2015 Ford Transit...
Unused Single Prong Kivel Bale Spear (A42021)
Unused Single...
2018 Isuzu NPR-HD 24ft Box Truck (A42742)
2018 Isuzu NPR-HD...
2015 Chevrolet 4x4 Tahoe SUV (A42744)
2015 Chevrolet 4x4...
