Anyone using a MMM with a 2025R or 2032R to mow their grass?
   / Anyone using a MMM with a 2025R or 2032R to mow their grass? #11
A 2xxx should be fine size wise with a MMM and Turf Tires, depending on your terrain and any obstacles that require driving under (low trees etc). I get a slight amount of soil compaction if mowing on wet spring soil with the 3320, but lawn is not a golf green so it's not a big problem. Depending on terrain / length of grass the higher HP end of the line may be a better choice to allow mowing in high range.
   / Anyone using a MMM with a 2025R or 2032R to mow their grass? #12
Once you mow with a diesel you will never look back!
Sent from my iPhone using TractorByNet
I mowed with a 2305 and 2320, than I bought my z465. I'd never go back my tractor. I don't think diesel has anything to do with it.
   / Anyone using a MMM with a 2025R or 2032R to mow their grass? #13
I mow with my 2520 with a 72"mmm. It has the R-4's on it. With the larger deck I don't seem to have to make as tight as turns as I did with the 60" on my previous 855 with the 60" deck, it had turfs on it. Had trouble with the 855 since it was 2wd getting around at times though. I think turfs with the 4wd you would be fine.
   / Anyone using a MMM with a 2025R or 2032R to mow their grass? #14
I have a 2018 2025r with the 60D. I mow 2 acres a couple times a week. My only change would be not getting the new radials. They are hard on the lawn.
   / Anyone using a MMM with a 2025R or 2032R to mow their grass? #15
I had a 2305 with 62C deck and Turf tires for 12 years. Cut OK with hardly any damage in wet clay soil. My 2025R with Radials weighs 1730 lbs and add the 60D at 365 lbs and that's a ton on wet clay soil. If you have topsoil, probably no problem. With wet clay, ruts even with the wider tires (have sunk to the front tire rims). But the cut of the 60D is much better. Now if only it would stop raining every darned day. Squish, squish, squish....
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2015 Ford Transit 250 Cargo Van (A55852)
2015 Ford Transit...
LANDHONOR BS-12-2500G (2) PRONG HAYSPEAR (A57193)
LANDHONOR...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
2008 Pierce Enforcer Ladder Fire Truck (A55852)
2008 Pierce...
