Spreader anyone used this spreader?
/ anyone used this spreader? #1
44trxfun
western NY
MF GC2300
I just got the new Forestry Suppliers catalog and saw this spreader Forestry Suppliers - Thompson 3PH Spreader. I know nothing about it, but I noticed they do not say it will spread sand. I was thinking of using something like this for a light spread of granular melters. Has anyone used one of these? Any thoughts?
/ anyone used this spreader? #2
Last line says it will spread ice melters.... </font><font color="blue" class="small">( Comprehensive spreading chart: lists fertilizers, seed, pesticides, ice melters, baits. )</font>
/ anyone used this spreader? #3
I hope that drive cable is inclosed
I know it (says it) will spread ice melters. I was kind of looking for something with the versatility to spread sand also, should I decide to go that route. I was really wondering if anyone had used one of these spreaders before and what their experience was. The price on this spreader looks pretty reasonable...
/ anyone used this spreader? #5
I'm using a Work Saver 3ph spreader for "traction aggregate", (my supplier's label) which is a fine crushed gravel. Sand tends to pack and clog and is polished which causes it to wash off the surface during melting or rain..much more so than the fine crushed aggregate which has rough, jagged edges that adhere to the surface. It's a little courser that sand and doesn't pack, even when wet.
I did install the optional roller agitator which would probably work sand. I just don't recommend sand for traction (unless that's all you've got).
/ anyone used this spreader? #6
One other thing..I think all of these spreaders will work fine. The major differences will probably be in the quality and materials used in their construction...hence..lifespan. All of the metering outlets will be similar to achieve the broadcast pattern and spread. The agitators will vary, which may be an issue with the product being dispensed.
/ anyone used this spreader? #7
Have not tried this spreader, but I am using a Herd Sand Spreader. It is specifically for spreading manufactured sand (more like fine gravel) with a hopper agitator, adjutable wings for modifying the spread and a grill on top of the hopper to ensure big chuncks do not get in and bust a shear pin. It is significantly more expensive ($1,100) but it works great and holds over 500 lbs.
/ anyone used this spreader? #8
I use a spreader from Tractor Supply Co. I believe it is made by Worksaver. I have the center wheel agitator and I use 10-10-10-10 fertilizer for ice and snow control. I was told about this years ago , no damage to bedding plants or grass. Does help green up in the spring. Very good traction on ice with this product. Mark
/ anyone used this spreader? #9
Fertilizer??? Does this melt the snow???
/ anyone used this spreader? #10
Most all fertilizers are made from 'salts-of-something' and so yes, they do melt snow & ice to some degree.
--->Paul
/ anyone used this spreader? #11
I jot got back from the fertilizer dealer and bought 200lbs of 12-12-12 $10 for a 50lb bag. One of the guys I work with uses 10-10-10.
They had some Urea(sp?) that was 46-0-0($20-50lb), he said thats what they use at the airport. I passed cause I thought it might burn stuff come spring. I'm new at this so what do I know?
This is cheaper than K-mart etc.. I haven't checked into bulk pricing like 1000lbs dumped in the back of my truck. Anyone have info on that, price comparisons?
Thanks
Chris
/ anyone used this spreader? #12
Bulk fertilizer at the farm is $200-400 a ton, depending on what formulation & the the price of natural gas this year....
--->Paul
/ anyone used this spreader? #13
wow thats a good idea I hate to put salt down.If 10-10-10 works why not anyone else hear about this?
/ anyone used this spreader? #14
If you use manufactured sand, it is only 4% salt, just enough to keep it from freezing into a solid block. It’s not like spreading pure rock salt. It only cost me $130 to have 10 tons delivered, so it’s a lot cheaper than fertilizer, and I don’t have to carry any bags round. Also, too much fertilizer MAY burn the grass in the spring, when it washes into the lawn, or feed some awful happy weeds along the side of the road.
/ anyone used this spreader? #15
While all these melting materials cause corrosion on vehicles if left unwashed, fertilizer is the most persistent (least soluable) on metal and in seams and crevices of your equipment. I won't ever use fertilizer for ice melting or traction on my asphault or concrete. In fact, I make sure I broom and blow the over-spread from my pavement when I fertilize my lawn in the spring and fall. Just my take on it...
2017 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2017 CATERPILLAR...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2002 STERLING LT9500 SERIES CRANE TRUCK (A67714)
2002 STERLING...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67737)
2012 INTERNATIONAL...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
