Anyone used high lift/dump bucket?
   / Anyone used high lift/dump bucket? #1
ShanClan
Florence, AL
Toolcat 5600 G; Kubota KX161-3; Ditch Witch 5610
I'm considering a high lift bucket for the toolcat so I can load with it.
Does anyone have experience using one on a toolcat?
   / Anyone used high lift/dump bucket? #2
over winter I use a high lift bucket and works great, never tried loading anything other than snow as its a 100 inch wide, even loaded full with snow there are times the weight is too much for machine, if I had a regular bucket size high lift I see no reason not to use one
I will note prior to the 2020 Toolcat I had a 2005 model, this did not work with the bucket due to the roll back when raising the arms
Thanks.
Mine is a G series, so the rollback should be ok..
I'm looking to load a single/tandem dump truck with standard height sides - (10 yd) with dirt. So, I was planning on a finding a 5' or 6' bucket if the height/reach works.
I have no idea how snow and dirt compare in weight as I've never loaded snow. I assume it depends on how wet it is - snow or dirt...
   / Anyone used high lift/dump bucket? #4
Is this what you are talking about?
Similar. I've seen that vid before, but could not determine bed height. This is what I want to load. The bucket pivot point on the boom is the even with the top of the bed (not including side boards). I've been building a loading ramp, but its not very efficient.
   / Anyone used high lift/dump bucket? #6
View attachment 662811View attachment 662812View attachment 662813
If you watch the video and compare the bucket pivot points and the bucket reach-over height, It would reach over your side boards.
Nice catch! Thanks.
I didn't take note of that in the video. I'm going to give one a try I think...
I'll keep everyone posted on how if works out.
   / Anyone used high lift/dump bucket? #8
ShanClan, my bucket for snow is a little different as my dump cylinders are at the bottom of the bucket, the hinge point is just behind the cutting edge so yes I could load this truck easily as the cutting edge would easily clear the truck
when clearing snow I never use the tilt function, once its set just lift and dump, my bucket is about 1 1/2 yard capacity
Great point about the pivot point and bucket design. I'm now looking at the varying manufacturer designs to determine the pros and cons of each - there are several...
Thanks for the feedback.
UNUSED SDLANCH SDLL60 STAND ON SKIDSTEER (A57192)
UNUSED SDLANCH...
2017 Peterbilt 348 Truck (A55973)
2017 Peterbilt 348...
2025 IRET 13 Utility Electric Tricycle (A55853)
2025 IRET 13...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
UNUSED FUTURE FT-HJ6 40' METAL STORAGE SHELVES (A57193)
UNUSED FUTURE...
2024 John Deere 6110M MFWD Tractor (A53485)
2024 John Deere...
