Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift
   / Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift #1
kraftymate
Panhandle Florida
2010 John Deere 5045D w/512 FEL and 2003 New Holland TC33 4X4 w/FEL
Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift, like to lift a plow blade or a tiller or snow plow, etc you get the idea?
I would like to mount one on my Garden Tractor as they are ALOT LESS than a tractor hitch.
Thanks a bunch guys!!!!!!!!
Kraftymate
   / Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift #2
how much weight do you plan to lift with it? its funny those are the exact same units as gm uses to apply a park brake on a motor home.
The push blade and drag do not weigh more than 100 lbs, and the T&T units I have seen will lift a 200 lb or more motor.
What do they call the unit on the motor home? I have never heard of them.
Thanks
kraftymate
   / Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift #4
auto apply park brake motor. I had a 24' regul "fun" boat and it had the exact same motor on it but it was an inboard motor so maybe what you are talking about is something different. if it works it should be pretty easy to set up, 12 volts and some lines. mounting position might be hard to find but its posible just check this out
YouTube - backhoe
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2010 Chevy Silverado HD Crew Cab (A52384)
2010 Chevy...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
