Anyone use taper-lock or B-lock hubs on shafts?
   / Anyone use taper-lock or B-lock hubs on shafts? #1
jimgerken
Minnesota
John Deere 3720
Has anyone used Taper lock or B-lock hubs on smooth shaft without cutting key slots, for power transmission? I am getting back to my snowblower project and am considering using this type. Thanks for your expertise.
   / Anyone use taper-lock or B-lock hubs on shafts? #2
Browning taper locks work really well, but beware of the cheap immitators.
Adding a drop of locktite to the shaft as the adaptor cone is installed is always beneficial, but you don't want to get it between the cone and the shive.
You also want to check the locking screws from time to time.
   / Anyone use taper-lock or B-lock hubs on shafts? #3
Jim
The company I work for use 2 different types of keyless bushing products.
They are Trantorque and Ringfeder
They both do a very good job of locking items to a shaft.
My favorite one is the Ringfeder. I don’t know what the cost is, but you will not have to worry about it holding. /forums/images/graemlins/smile.gif
BDI carries these products. Look under Manufacturer Retaining Locking they have a full list of different manufacturers.
   / Anyone use taper-lock or B-lock hubs on shafts? #4
All the ones I have used had keyways or I cut them in.
Getting a keyway cut shouldn't take much.
Do u have a Career Center nearby?
They will do it cheap or free.
Since u do work at home consider getting a used Bridgeport
or clone milling machine.
They also make GREAT drill presses.
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
