Anyone use Slime in gator tires?
   / Anyone use Slime in gator tires? #1
chipsndust
Platinum Member
central NY and Adirondacks
JD 1025R, Curtis cab
I got my first puncture yesterday in driver's side rear tire (XUV 850D). I drove over a "punji" in a recently cleared trail. I used a DC compressor to inflate the tire to get out of the woods. It looks like it's holding pressure with the repair I made.
I usually take care to cut saplings and brush low, with a flat top, so I don't expect to have too many incidents like this, but I'm thinking the Slime might help prevent another incident.
I haven't used Slime in my tractor or gator, what do you guys think?
   / Anyone use Slime in gator tires? #2
I used Slime to stop some slow leaks in tires recently. I wouldn't trust it to seal a larger puncture from a sapling. I think you would be better off removing the tire and installing a patch inside the tire.
   / Anyone use Slime in gator tires? #3
I put it in all 4 tires on my 4 wheeler. The locust thorns were causing me to have pin hole leaks on a regular basis. The ATV type slime has eliminated those problems. I'm a firm convert if you have a danger of small punctures.
   / Anyone use Slime in gator tires? #6
Slime is about as important as the fuel that goes into our Utility vehicles and ATV's.
Without it, we wouldn't go very far >>>>
The Kubota, has 1/2 gallon per tire
The Honda Rubicons, 32 oz. bottle per tire
Slime does work wonders >>>
Honey Locust in the swamps is heck on them tires >>>>>
Thanks, guys. I've only had one puncture, and I would just as soon not have a repeat. I put about 20 oz. in each tire, so far so good.
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
49205 (A55788)
49205 (A55788)
Caterpillar 906M (A53317)
Caterpillar 906M...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
