Anyone use a Kubota RTV900 with a FarmBoy 3 PT Hitch
   / Anyone use a Kubota RTV900 with a FarmBoy 3 PT Hitch #1
LM80
MO
Ford
Hi there,
This is my first post but have used the site for much helpful info. I have a Ford 2n tractor that I use a few implements on: 5'Grader Blade, Boom, Middle buster, Carry All, and looking to get more. I am looking at getting a RTV900XT to help move firewood and other things around the house. I was wondering if the RTV900XT actually had enough power to work with these implements if I get the FarmBoy 3 point hitch for it. I was also wanting to know if anyone has used a box blade and if it was strong enough for that. Am I waisting money on the Farmboy with the RTV900, or will it work? Or should I just stay with the 2n tractor, but I'm looking to get away from it because of the reliability. Thanks for any info you may have.
   / Anyone use a Kubota RTV900 with a FarmBoy 3 PT Hitch #2
Welcome from Ohio
   / Anyone use a Kubota RTV900 with a FarmBoy 3 PT Hitch #3
I have used mine to pull a long drag to level off the pasture after disking. It will start to run hot if you peg the pedal for a long time with a heavy load like that. I would say you could pull a small cultivator or row hipper with it, box blade??? Maybe if you don't load it too much but I don't think they were made to use ground engaging tools. It will pull a heavy trailer well though.
Do you think for short term yard use the box blade would be fine? I won't be using it but here and there. And probably not very long each time. I think my tracror is finally getting to the end of it's use without needing more $ dumped into it. And do you find that the Farmboy is worth the money for your use? Thanks
I am planning on putting the snow plow on the front as well. Do you have any use with that?
   / Anyone use a Kubota RTV900 with a FarmBoy 3 PT Hitch #6
I don't have any use for a snow plow but the RTV 900 should be really well with a snow plow. I have seen many post here for guys using them with snow plows. I think much has to do with how your transmission is adjusted. Some owners complain about not having any power to climb hills etc, but I haven't had any issues with my 2009 model. I think the main reason for complains about power is lack of knowledge on how to drive a HST transmission. If you start to stall down the engine, just back off the pedal a little and it powers right on up. I think those saying it wont pull are just putting the pedal to the medal which is not the way to do it.
I have used mine to yank saplings out of the ground by using a chain on the ball hitches that I installed in the front and rear receivers.
Thanks for the info Gary! It looks like I'll be putting enough money out with the RTV900 itself. The Kubota snowplow is $1800, and if I could use the 3 pt hitch for a bit more money it would make the machine alot more versitile for me. Just don't want to be spending it when it won't work for me.
Dump Hopper, 43" W x 39" D (A59076)
Dump Hopper, 43" W...
LOT: Air Hose Reels, 220 V Cord, Electrical Cords, Hand Tools, 2-Wheel Hand Truck (A59076)
LOT: Air Hose...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
2022 ALLMAND LIGHT TOWER (A58216)
2022 ALLMAND LIGHT...
