Anyone use a Duramax? Fuel transfer.
   / Anyone use a Duramax? Fuel transfer. #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
"Flo n' Go Duramax Fuel Caddy"
Flo n' Go Duramax Fuel Caddy 14-Gallon Capacity, Model# 06792 | Auxiliary, Transfer, + Skid Tanks | Northern Tool + Equipment
I'm looking for an interim fuel moving capacity between the 5 gallon can and my 300 gallon IBC. But elsewhere I've read that
Gasoline carried in quantities per
container greater than 8 gallons per container must
comply with the following:
1. The package/container must be marked on one side
as follows:
Gasoline
UN1203
2. The package/container must be
labeled with a class 3,
flammable liquid label.
3. Shipping Papers must be carried
along with an MSDS sheet for gasoline.
http://telsafe.org/Documents/NTSPGas-DieselFuelTransportation.pdf
So does anyone use one of these? What about the paperwork?
   / Anyone use a Duramax? Fuel transfer. #2
Lots of guys use them at the lake. Work great.
Chris
   / Anyone use a Duramax? Fuel transfer. #3
The work good, but are gravity flow, so its not great for my tractors as the fill port is above their level when on the ground.
If I was going to use it for my Kubota I'd probably lay it in the FEL and get gravity to be my friend.
   / Anyone use a Duramax? Fuel transfer. #5
I have one. The hose is very stiff.even being very careful it is easy to kink hose. Then after about 1 year the nozzle started leaking.
   / Anyone use a Duramax? Fuel transfer. #6
I bought 2 of these used for $40.00. One was still new in the box. I can't say in thrilled with them. They seem heavy , clumsy , and fill very slow. Plus you have to get the above what your filling. Not practical for larger tractors.
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2018 FREIGHTLINER...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
