Anyone try the Northern Tool magnetic flood lights?
   / Anyone try the Northern Tool magnetic flood lights? #1
boomer632
Steeler Country
2011 LS R4041EZ - 2014 Bad Boy CZT Elite - 1948 Ford 8N
I bought a couple of these lights to mount to my ROPS. They run off a 12v cigarette adapter plug. I have already installed a plug wired to a keyed power supply. The lights are 55w each. I want to run them off the adapter for a while before I decide to hard wire them. Would it be too much of a load to run them through this 1 in / 2 out plug adaper to power each light?
Anyone ever tried these lights on their machine?
Peterson Manufacturing Magnetic Mount Floodlight 12 Volt | Automotive Work Lights | Northern Tool + Equipment
   / Anyone try the Northern Tool magnetic flood lights? #2
I used that exact one when I had my BX24. I was really pleased with how well it worked. Stuck it to the underside of the top bar on the ROPS.
   / Anyone try the Northern Tool magnetic flood lights? #3
Is the adapter rated 10 amps or more, 2 55w light draw about 9.5 amps
Ill have to check on that...
Just looked at one at local Advance Auto.. rated at 10 amps. Should be good then I assume..
   / Anyone try the Northern Tool magnetic flood lights? #5
I used one of these lights several times. Mostly during cutting hay and not finishing before dark. Mount on hood or fender to help watch for little deer bedded down. Also helps out when using loader after dark.
JOHN DEERE 333G SKID STEER (A52709)
JOHN DEERE 333G...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56435)
2017 John Deere...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
294 (A52706)
294 (A52706)
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
