Anyone thought about building a corn picker?
   / Anyone thought about building a corn picker? #1
Dachshund
Nebraska, USA
Ford 8N, International 454, Farmall M
Like the ones that used to be towed behind the tractor and picked the ears, but didn't shell the corn? I thought about delving into it. Any ideas would be helpful!
   / Anyone thought about building a corn picker? #2
I have an old pull behind one-row corn huskor I had dragged from the farm across the street.. it has all the parts.. but would need a lot of work.
The MF65 I bought a few years ago.. has a mounted 2-row corn huskor. This fall I used it to harvest my field corn. I lined the inside of a wooden hay wagon(8ftx16ft) I built w/ 2x2 wire mesh. I was pretty impressed that it would even harvest the stalks that are laying flat on the ground.. you just have to go a little slower.
If you weren't so far away.. I'd be happy to give away the one row just to see someone restore it.
   / Anyone thought about building a corn picker? #3
Yes, but no idea where to start. I certainly hope you get some reasonable responses, or even people giving enough info on old commercially manufactured ones would let us have some ideas. I am thinking of growing up to 10 acres this year, depending on how much water is in the river in May (for irrigation) but a minimum of 2 acres. Knowledgeable people please butt in. Old McDonald.
Yeah - I'd have to take you up on it if we were closer!
   / Anyone thought about building a corn picker? #5
Not sure where exactly you live. But around here we have the agtrader. It's got several sections you could such implements used. There are sections for both working and scrapped implements. Aswell as I have seen several 1-2 row corn pickers.
   / Anyone thought about building a corn picker? #6
Around here (southern MN) one row units are sold for scrap iron, 2 row units only slightly above. I can't imagine engineering such a machine on your own. They are rather complex in their tolerances to do what one wants them to do.
I have a NI 300 & a 327 (the newest wide row) I think? One was $30, the other $135. There are parts from the NI 6A in the grove, got it from the neighbor 20 years ago for $100. It just plain wore out. A good narrow row 2 row unit goes $400, and a dealer was advertising a 3 row pull type last fall for $1000.
Have you looked for an old but servicable picker around you?
--->Paul
Been looking for one close by, but most I find - I'm a day late - they're already cutting it up for scrap!
   / Anyone thought about building a corn picker? #8
There are no such machines in this part of the world. In fact there is very little of anything except ploughs, scarifiers and tpl boxes. I cannot even find anyone with a small grains combine harvester. I build most of what I need - harrows, subsoiler, seed drill, land leveller, rock rake, even a two pronged hay fork. Most people have very small plots and cut with a sickle type implement (not even a scythe). Bigger plots are cut by contractors with a ride on motorised reaper followed later by a baler. Some also bind hay or small grains crops into sheaves. A neighbour does a wee bit of threshing of corn and oats, but he uses a flail. Any links, photos or how to get started would be most welcomed. Old McDonald.
   / Anyone thought about building a corn picker? #9
I havent been around a cornpicker that much except for a feed pickers. A fresh corn pckers has rubber fingers I think. I Know a mans here that has afront mounted basket that attaches to the front of his tractor and has casters out front. its hinged to follow the ground and has a platform like a man basket on the top. He has 2 inverted V's on the front to on each side to make the stalks go into the the basket and 2 workers pick it as it comes into the basket. Works pretty good. He found if the ears miss the workers the back of the v hangs them and pulls them up. He wans to try smeting with this the make a simple picker. He plants most of his corn a week apart in rows of 10 so it wont all ripen at the same time.
Old McDonald Id like to see your rock rake and land leveller. I worked 2 summers around and alot of them down in the delta. Neat how many desings they have.
   / Anyone thought about building a corn picker? #10
Sorry, unable to post pics. I will try to learn. My son will be here in early April, and I will ask him to do it for me. Neither implement is anything flash. In fact the land leveller is just some very heavy walled pipe welded up to tow behind either my scarifier or some 3 metre wide harrows I made up. Old McDonald.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2004 FORD E350 MECHANICS TRUCK (A52576)
2004 FORD E350...
BUSH HOG 3308R-2 LOT NUMBER 118 (A53084)
BUSH HOG 3308R-2...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
