anyone switch to LED lights?
   / anyone switch to LED lights? #1
herm0016
Platinum Member
Carter lake, Colorado
Branson 4720h
Going to upgrade the work light to the HF led flood, need to either add a switch or change it to turn on and off with the head lights. also, thinking of installing LED headlight bulbs and flasher/running light, brake light bulbs. have you done this, has it worked out with the flashers? any recommendations on bulbs?
   / anyone switch to LED lights? #2
Why bother swapping brake lights and turn signals to led? Waste of money. But swapping head lights and work lights is a good idea. I was never sold on swapping to LED until I did a side by side comparison. The LED flood won out hands down. But I didn’t get a cheapo HF light as I never have any luck on HF stuff. I went with a quality CREE fixture, and after 5 years there still going strong.
I didn’t swap head lamps because my cab tractor has upper front and rear floods. The head lamps are usually blocked by the bucket anyways.
this is my 2¢ worth
   / anyone switch to LED lights? #3
It's too bad that work lights with switches are not that common. The stock one could use improvement.
Many times the drop in LED bulbs are not in exactly the same place vs the reflector as the original bulbs. With road vehicles' headlights that can result in poor light patterns and blinding oncoming traffic. But the few times I have tried this on a road vehicle I took them out because the pattern was bad. Instead I used higher quality brighter halogen bulbs. It's less of an issue for a tractor being operated off road.
Often the flasher relay needs to be changed to work with the lower current draw of the LED bulbs. Last time I did this on a road vehicle I found a plug in LED-friendly replacement.
   / anyone switch to LED lights? #4
Herm,
Are you having to operate your tractor along a roadway, or road it down a public highway?
Just wondering what the goal here is?
I doubt I would replace mine with LED. On the cab tractor (at least mine) it came with 2 front and 2 rear worklights. They are "bright enough" for my needs, but if I'm operating in the dark, it's usually along an area I know well (like mine or a neighbor's driveway, etc) and I'm not worried about unknown objects.
And I agree with GRS, the headlights are often blocked by the bucket if I have that on. I still run them of course, because they do add light to the general area.
   / anyone switch to LED lights? #5
I've added two front flood LED lights for the front and two for the back. It makes a tremendous difference on lighting the area around tractor. I've also thought about replacing the brake lights with LED bulbs since those heat to much that I'm sure the brake light lens will become brittle over time.
Here is the front ones. Two 18W flood lights. Left is with just the stock halogen lights and right is halogen plus LED flood.
The rear has two 36W flood lights but I have no pictures on the dark with those turned on. All of these aftermarket lights are just Chinese specials. They seem to work just fine.
End up plowing snow in the dark quite a bit here, drive is about 1500 feet long to the dirt road and there is very little light pollution in our valley that runs north and south. sun raises and sets maybe 45min early and late due to the mountains on either side of a narrow valley which makes day time pretty damn short in the winter.
the HF road shock lights are actually very good. and I have one in stock from my previous tractor.
was thinking of changing them to LED because about half of them are out anyway. LED's have much better shock resistance than incandescent, esp. in the cold. first thing I did on a new to me oilfield unit was switch all the work and warning lights to LED. lasted way longer, brighter.
I have a sunshade/rops may put a couple floods up under the sunshade as well, but want to get all the stock stuff going first.
maybe i'll grab another of the HF lights for the sunshade and find one with a switch for the work light. this is tempting, 50% brighter too.
probably right on the headlights, as something brighter may hinder vision in the snow after bouncing off the bucket. I am not a huge fan of light from above when its snowing though. maybe mounting to the holes on the glass frame by my feet for a pair. or point some halogens at my feet for when its really cold, haha!
   / anyone switch to LED lights? #7
I'm all LED's now and will never go back.
LED's even outperform the Halogens they replaced.
For my main front it is a 12 LED 'bar' that has the 4 centers as spots and the outer 4's as floods.
Rear work are 4 " LED floods for snow duties.
Even my cab interior is now a 12" LED strip, and that's literally night and day.
My turn indicators are now also a LED strip.
My 'Stobe' is a DIY deal using the old lens and a bunch of LED's.
When U replace flashers U need to add a resistor as LEDs simply don't draw enough current to operate the flasher device.
Best of all is the durability of LEDs vs filament bulbs and their short life.
Another consideration is that many CUTs have low generator output.
With the much lower power drain of LEDs you usually can add a lot more lighting using the same factory wiring and switches.
   / anyone switch to LED lights? #8
my upper lights cause no issues in snow work on my cab unit. They place light out very far. I have to remember to kill them if working along road with oncoming traffic…..blinds drivers.
i generally only use my cab led lights during winter snow removal. In spring thru fall it stays light long enough not to need them.
   / anyone switch to LED lights? #9
My experience has been similar to GRS. I get much more area coverage from the 4 work lights (2 front and 2 rear facing) than I could with any light hood height or lower lighting angles.
"Darkness in Winter".... Yeah, I've heard of that (LOL).
I'm still using the factory installed standard work lights that came on the cabbed Branson's for many years:
I had to replace the bulb in this one after hooking it on a tree limb a couple years ago. I got lucky in that it only managed to yank the bulb out of the housing. It broke the bulb, but the housing and the wiring connection were fine.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
TRUBILT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
TRUBILT SKID STEER...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
