Grading Anyone running skid shoes on a rear blade?
   / Anyone running skid shoes on a rear blade? #1
bxowner
Vermont
John Deere 5055e
I have the Frontier RB1072 and the i-match. The top link is dialed as far in as possible to minimize the blade edge from cutting into the ground. But I still get a washboard effect - the blade is bouncing and cuts into the ground, then bounces, cuts, etc. Wondering if anyone has experience with the skid shoes and if they help.
   / Anyone running skid shoes on a rear blade? #2
I have the shoes for mine and like them, but if you are chattering, you are likely going too fast.
Chattering begins from the moment I start up in low range... my driveway goes uphill and I simply can't build up any 'speed' to speak of - in fact, by the time I get about 40 feet, the engine really bogs down. Then, when I get on the dirt road and head downhill, I put it in high range - and the chattering goes away completely.
I'll probably go ahead and get a set, thinking that (1) it will help reduce the 'chattering' by separating blade from direct contact with the ground and (2) perhaps help with the bogging down.
   / Anyone running skid shoes on a rear blade? #4
Yes, they help on gravel driveways keeps the blade from digging up the surface. I don't use them on pavement.
M.D.
   / Anyone running skid shoes on a rear blade? #5
I would not consider using a rear blade without skid shoes or a rake without gauge wheels. Being able to set depth of the blade makes the tool much more useful. I winter I use the blade for snow clean-up on a gravel drive (after plowing with my truck & plow) and the skid shoes allow me to set the blade just above to gravel so as not to dig in.
   / Anyone running skid shoes on a rear blade? #6
I am curious , any one have a pic of these skid shoes? I never saw a pair, are they similiar to plow shoes on a snow plow? And how do they mount on the blade?
Thanks ,
Macdabs
   / Anyone running skid shoes on a rear blade? #7
I'm wondering if you're angling the blade or using it straight across the back of the tractor? I've had better success using the blade angled to reduce the chattering effect. However......I have since added cupped snow plow skid shoes to my blade that I have grown to appreciate.
Don
   / Anyone running skid shoes on a rear blade? #8
   / Anyone running skid shoes on a rear blade? #9
mtg65,
Thanks for the pic , they are like on a snowplow, almost identical as the pair on my four wheeler plow.
Macdabs
   / Anyone running skid shoes on a rear blade? #10
Here's a picture of the shoes on my Rhino blade. They help on my gravel driveway, but I always leave an inch or so of snow that likes to turn to ice after being driven on. Still it's better than taking off a layer of gravel by trying to plow a little closer.
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2012 International 4300 Reefer Truck (A55301)
2012 International...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2005 Eager Beaver 20XPT (A47477)
2005 Eager Beaver...
