Anyone run a generator of the mid pto?
   / Anyone run a generator of the mid pto? #1
jobguy
MN
Bobcat CT120
I have a Bobcat Ct 120 with 14 pto hp. Will I be able to run a generator large enough to power my home off the mid pto? I was thinking of maybe running a shaft 90 degrees to the side and leaving the loader in place. Any suggestions?
   / Anyone run a generator of the mid pto? #2
bad idea for lots of reasons. You have enough power for 7kw which is marginal to run a home.
also, with the U-joint at that angle you'll get some surging as the RPM's change as the shaft rotates. That will mess with your A/C sine wave and could damage electronics in your home.
   / Anyone run a generator of the mid pto? #3
Your mid pto is 2000 rpm.
PTO generators are 540 rpm for the rear PTO.
   / Anyone run a generator of the mid pto? #4
exactly what dusty said. I am not sure if you really want to make alot of modifications to adapt a generator to use the midpto speeds. Most if not all, uses the 540 rpm rear pto speeds.
Is there a particular reason why you wanted to try the mid pto for generator as I fail to see the logic of it.
I was thinking I could run the engine at a lower rpm while maintaining 540 mid pto rpm, saving engine wear and tear as well as fuel.
   / Anyone run a generator of the mid pto? #6
That would be true if you had a 50 hp pto and were running 20hp or so out of itand did not mind messing with pullys and belts to get the correct rpm. Diesels have a wide torque curve but it looks like you can't spare any at lower rpms anyway. CJ
   / Anyone run a generator of the mid pto? #7
hmm, I dont think this will work. lower rpms means much less power so when lets just say a refrigeration unit comes on, the genny is under stress to cope with the surge load before going to a running load and your tractor might stall or struggle causing more wear then it should.
A diesel tractor is designed to run hard all day long with power not the other way around.
   / Anyone run a generator of the mid pto? #8
I agree your HP is too low.
I've debated a PTO generator for more power but more I look at it I'm just sticking to my gasoline powered stand alone generator.
   / Anyone run a generator of the mid pto? #9
Me too. The idea of unhooking a tiller / bush hog (or whatever is attached at the time) when its raining and the power is down; then hooking up a PTO generator sounds frustrating to me.
I know another engine creates hassles and gas consumption are factors but the gas generator is parked out back under cover and all I have to do is start it up and hook up the cord to feed the house. That is much easier when raining cats and dogs. I use fuel stabilizer and start the generator at once a month and let it run for 0.5 hr.
A PTO generator seems to much hassle to me. Especially trying to use a mid-PTO.
Thanks for the advice, I will think more about getting a portable generator that will work. OR.... Move to TX where you don't freeze to death when the power goes out. :thumbsup:
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
