Anyone recommend a hard wired battery jump start system for truck?
   / Anyone recommend a hard wired battery jump start system for truck? #1
Hay Dude
Super Star Member
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Would like to hard wire a battery jump start plug to my truck grille so I can jump start dead batteries a little easier.
Anyone have such a set up they can recommend?
   / Anyone recommend a hard wired battery jump start system for truck? #2
I havent done it, but if I was going to do it, I would use Anderson Powerpoles, with a littl No-ox-id smeared on the connector. Anderson powerpoles are self cleaning and very rugged connectors. They are often used in industry. As an example they are often used in lift trucks. I use the little ones for all of my Amateur Radio 12 volt connections.
SB350 SB Series 350 Amp Anderson Powerpole Set
james K0UA
Thanks, I was more looking for a kit I could install in a few minutes on my truck.
   / Anyone recommend a hard wired battery jump start system for truck? #4
Check the on the AW Direct website.
   / Anyone recommend a hard wired battery jump start system for truck? #5
I have put a few in and have a set-up in my service van since 1990... the only downside is having another battery to replace when it's time.
I mounted a second battery in a heavy duty boat battery box next to the spare tire inside my van and made up batter cables to reach.
The rest involved a battery isolator to charge the second battery and adding a second Ford type starter solenoid wired to a switch on the dash... the solenoid I bought is rated for continuous duty.
Since 1990 I have run a Statpower inverter that is large enough to power my small compressor and all of my power tools except it doesn't like my worm drive skill saw.
The inverter runs off the second battery or I can flip the switch to link both batteries and if I need more power... I can also start the engine...
After a couple of years I upgraded my alternator to 130 amp when I had the chance...
Friends owned Ford Pickups... they were gas models with room under the hood for a second battery if the truck had been diesel powered... on these, I just ordered the OEM second battery box...
Have diesel truck w 2 batteries.
   / Anyone recommend a hard wired battery jump start system for truck? #7
   / Anyone recommend a hard wired battery jump start system for truck? #8
I bought 6 of those plugs in that link post above , a spool of 4 gauge wire ??? ( maybe 2 gauge or bigger , been awhile since I did this project , it is big stuff though , bigger than any store bought cables ) . On one end of cable , I placed a brass battery style bolt hole lug in vise and filled with melted solder and shoved wire in . other end got the same treatment , but with lug from inside plug . This wire runs from my battery in engine compartment all the way back to receiver hitch at rear were the plug is mounted . It will run my jumper cables or also a Harbor Freight 2000 lb. winch which is mounted to Our game hoist for Elk Hunting . Makes it nice when giving somebody or something a jump start , in that I don't have to turn around , Simply pull over in front of them and back up . It has caught some people by surprise , Stop , See if I can help , They need a jump start and they have this Bewildered look on their face when I back up within about 6' of the front of their vehicle .:D
Spool of wire and plugs ( Bought both on Ebay ) totaled some were around $100 which is half the cost of a kit . Customized to my criteria .
Fred H.
   / Anyone recommend a hard wired battery jump start system for truck? #9
I also installed commercial jumper cable with quick connect on my service truck... sure makes it nice not having to open the hood.
2014 Ford Explorer XLT SUV (A50324)
2014 Ford Explorer...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
KSI Conveyor (A52748)
New Holland B95 Backhoe (A50490)
New Holland B95...
