Anyone put up a ARCH building before?
   / Anyone put up a ARCH building before? #1
smilingreen
Lebanon, Tennessee
JD 5055D, JD 790 MFWD
Hey all you tractor dudes,
I purchased a 26' x 40' ARCH building this fall and am in the process of putting it together (adult erector set!!) Do any of you guys own one or have erected one? /w3tcompact/icons/shocked.gif (a ARCH building, that is /w3tcompact/icons/grin.gif ) /w3tcompact/icons/blush.gif Just wondering if you have had the same problems I am having putting this thing together. The whole building came in on three skids, all banded together and dropped off on my concrete slab. After disasembling the skids, I found: No instructions, some materials that I don't even know what they are for, and damaged parts. Well, I straightened out the damaged sheet metal, called the factory about assembly instructions, and they faxed me a poor...very poor set of assembly prints. These things were hand drawn in 1959..I kid you not. No exact deminsions for the concrete slab, just generic X2 numbers. Called the factory again, and they told me the deminsions for the concrete pad. Well, anyway, as I am starting to assemble the arch pieces, I find that some pieces fit together well, and other pieces you have to wrestle with and use long spud wrenches to make the holes line up. This usually makes one of the sheet metal mating holes tear. The company sent me two boxes with about 3500 fasteners apiece in them, and about 7000 nuts. (are you beginning to get the picture of a adult sized erector set??) The rep that I bought the building from said that I could put the building up in one day with a crew of 4 people. Well, I have been at it for about 5 full days and have only put up 2/5's of the building so far. What kind of weed was this guy smoking to lose track of that much time??!! I hope to have the main arches finished by next weekend, and then I have to put up both end walls. I hope these go faster than the arches do. It came with a 10' x 10' garage door, but I think I am going to hire someone to put that in. The top of the building is 15' high and altogether 26' wide, which gives the building a lot of room inside without any support beams inside to bump into with the FEL. I like that part about it. Plan on storing all my implements inside, along with both my tractors and my 26' long sailboat. Better half mentioned something about furniture storage.......I don't know about that one... But on the brighter note, the building only cost about $6000.00 as a kit. I guess I can't complain too much.
   / Anyone put up a ARCH building before? #2
Dave,
I hate to be bearer of bad news but those buildings are the worst. Like you have found out they are ridiculous to put up, they leak, and they are not very sturdy. More have blown down around here than have stood up. I really hate to tell you that for $6k you could have bought a very nice pole building kit with more features and at least the same size as that one. You couldn't even give one of those to the farmers around here. I wish you the best with it and hope it works out for you but I would really try and get some kind of compensation for it.
   / Anyone put up a ARCH building before? #3
I am in the process of doing so. My building went really well for the first 10 or so (of 18 sections). Then we (my brother and I) hit all kinds of serious problems - things not fitting together, etc.. We fought those demons for 2 days, then my brother had to return to work. Just before he left, we figured out what hat happened.
The way this one goes together, there is a channel along the bottom, which enforces a 24" pitch to the arches. The top sort of drifted until we were about 3" off plumb (the top was 3" out from the bottom). This happened because we didn't use some angle iron spacers which were supplied to keep things lined up. Our mistake - we didn't follow the directions. I have put the project aside for now, because I need some help and the Canadian winter gets a tad cold when you are working with steel (especially without gloves).
If it would be a help I could probably get you a copy of my installation manual.
Nonetheless, I am confident that I will get this thing together ok in the future. As to the reliability, water tightness, etc., there are plenty of these type of buildings up here, ranging from barns to garages. They seem to last a long time, and from my perspective should fit the bill. Mind you, they are ugly.
   / Anyone put up a ARCH building before? #4
OUCH! /w3tcompact/icons/shocked.gif
$6,000 and you still have to assemble it yourself? /w3tcompact/icons/frown.gif
I paid $3486.54 for my 24x36x8 pole barn materials, 26 tons of gravel, and 4" concrete slab and they quoted $7500 for materials and labor to asseble it themselves. My wife and I did the labor. It took 4 weekends over a six week period for us to complete.
   / Anyone put up a ARCH building before? #5
How where you able to build a building sooooo inexpensively? /w3tcompact/icons/shocked.gif The labor savings I can understand - but the materials costs must be somewhat cheaper in your area.
Terry
   / Anyone put up a ARCH building before? #6
When you say an "ARCH" are you talking about a quonset hut building? There are lots of these building in my area. Relatives that have them like them because they are free span and combines, grain wagons etc can be moved around inside without worry of hitting posts. I must admit though, most are 1960's era and i haven't seen any new ones going up recently.
Good luck, after its up I'm sure you'll be happy with your choice.
   / Anyone put up a ARCH building before? #7
Well I caught the siding on sale at $.99 per foot (reg. $1.69). The four 24' trusses were $75.00 each. $235.80 for 26.4 tons of #57 gravel. The 11 treated 6x6 posts were only $32.20 each. I got blemished windows and door so I saved a little their.
As soon as the weather dries up so I can level out a spot to build on I will be building a 20x24x12 roof only with one wall (to hide its contents from the house view) and was quoted last week $935 for all of the materials deleivered from one company and $1016 from another. The first quoted me $1995 erected and the second quoted $2186. We will be building it ourselved.
Another price consideration maybe that I don't have to meet every nit pickin' code since I live in the county. At my last residence, I would have had to use 10 trusses and 22 poles even though the steel trusses are rated to be used up to 12 feet apart. but CODES/w3tcompact/icons/sad.gif there state no more than 4' apart REGARDLESS!!!!!
   / Anyone put up a ARCH building before? #8
Cedarranch,
Those are excellent prices!/w3tcompact/icons/shocked.gif Did you also pour your own concrete pad?
   / Anyone put up a ARCH building before? #9
Bingo - your last paragraph said it all. Looks like your reduced your material cost nearly by nearly a third (give or take a little). Good for you! /w3tcompact/icons/smile.gif
Oh well, I have to contend with zoning and covenants (The covenants being the easy part believe it or not).
Terry
   / Anyone put up a ARCH building before? #10
I have done pads in the past - Super lot of work and I paid for it over the next few days. /w3tcompact/icons/wink.gif On this one, I did all of the prep work and framming and had two guys in the business do the pad while I relaxed and watched. /w3tcompact/icons/cool.gif They did a super job - 3 years and not a single crack. On my last property I did 2 myself. One 20x30 for my shop and one 16x24 for my tractor and 250' of boat ramp/drive way. Told myselft I was getting way to old to move concrete! /w3tcompact/icons/smile.gif
CAT Skid Steer (A50322)
CAT Skid Steer...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
Ford E550 Bucket Truck (A53117)
Ford E550 Bucket...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2007 Mack Granite CT713 Day Cab Truck Tractor (A53117)
2007 Mack Granite...
