Anyone put a tow hitch on a flail mower?
   / Anyone put a tow hitch on a flail mower? #1
Weedaway
South Australia
David Brown 885
This would be pretty useful for me, but I'm worried the mower body might buckle. It's an older Caroni 1600. The trailer is not large. Let's say under a ton laden. I could use a tube across the back for reinforcement but then the forces would just transfer through the end plates to the front of the body at the hitch points, right?
No I don't intend to be mowing with the trailer attached :)
   / Anyone put a tow hitch on a flail mower? #2
I’d think you’d be fine. I assume you’re talking about short tow distances? Probably wouldn’t do it down a highway at 70 mph
Implements are, for the most part, built relatively solid
   / Anyone put a tow hitch on a flail mower? #3
I modified my bush hog by adding a 2 inch receiver hitch for moving empty trailers around. Its easier than taking off the implement each time. Keep in mind your 3PH loses capacity the further away the hitch is from your tractor. I have no problems moving empty trailers or heavy trailers on level ground.
   / Anyone put a tow hitch on a flail mower? #4
This is just me. I'd never put a hitch on the back of any kind of mower/brush cutter. I can hear the Engineers screaming in the background. :)
   / Anyone put a tow hitch on a flail mower? #5
I have a rear hitch on my box blade and flail mower.
As a previous poster said, it’s nice to move a trailer around with on the place without dropping the implement.
I guess moving empty trailers around the yard is prolly ok. But my needs involve rough ground and loads of firewood. So I'm going with caution on this. Not worth busting stuff. Thanks for the replies.
   / Anyone put a tow hitch on a flail mower? #7
We have a Seppi brush flail mower and installed hooks for skidding chains on the back. I welded on a pad to spread the load out, it was an oval about 10" long, then welded the hook in the middle of that. I think the housing is the metric equivalent of 3/16 steel. It is a little heavier unit since it is rated to 4" hardwood mulching.
Yeah the Seppis look nice. Coupla notches heavier than a Caroni.
   / Anyone put a tow hitch on a flail mower? #9
They sure would scream if they say me with the guard off pulling a piece of heavy nylon material catching the clippings thrown back. Cleans the yard up like nothing you ever saw. Shoot me my yard my tractor nobody else around.
   / Anyone put a tow hitch on a flail mower? #10
I am the same way. I bought an $18,000 log trailer and the first thing I did was modify it. Blew the warrantee right out the window, but what do I care, I bought it to do work, not whine to the manufacturer that got a ding on it. I routinely send the engineers pictures of my modifications how versatile their orginal machine can be.
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2018 Kubota U17 (A53317)
2018 Kubota U17...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
