Anyone out plowin?
   / Anyone out plowin? #141
For rust determent----
Heat RAW linseed oil and spray that as you would with any undercoating product.
Head will thin it out for spraying.
Linseed oil will not clot or skin up and has an affinity for rust.
A drop will get itself sucked up by any rust nearby like in seams etc.
Heated make it act like diluted and gels quite rapidly as it dries.
Aviation has used RAW linseed oil to protect steel tubing structures ever since.
Downside is the sweet smell that'll linger for a while.
I proved this way back when we had a VW beetle that was notorious for rust.
   / Anyone out plowin? #142
   / Anyone out plowin? #144
guys if your looking for a rust preventer, this stuff is amazing, i use it everywhere, bare steel in the rain for 3 months with no rust...
Amazon.com: Fluid Film & Woolwax 1 Gallon Undercoating Kit Bundle w/PRO Gun & 2 Wands. Straw(Clear) Color.: Automotive
That product is OK for areas that are obviously exposed,....and can be accessed visually.
It is much too viscous to protect the seams of metals that are crimped, or spot welded together.
Cars and trucks rust most frequently in areas where salt and debris gets trapped, areas that are not readily accessed.
   / Anyone out plowin? #145
Cars and trucks get the most rust in areas that cannot be readily accessed.
When it gets hot out the ff runs into all the seams...I spray my truck in the summer....
   / Anyone out plowin? #146
the stuff was literally designed for undercoating cars, there are a ton of youtube video's on how to properly undercoat a car, which i have done. it gets in every orfice you can think about. it comes out like a mist, and can creep, have you actually used it? i can get it in door panels and other sections with 0 issue.
   / Anyone out plowin? #148
Maybe......but you only see what is obvious.
If you do the door bottom seams inside, just take a door trim panel off and compare.
Or....the seams inside a tail light housing, or inside a front directional.
I know LPS-3 does a much better job!
Check out the LPS-3 MIL spec.
Sorry to burst your bubble Peter, but that "spray kit" is homeowner feel good equipment!
It is not even on a level similar to the mighty Wagner Power Painter.
Oh sure, the "kit"..... will spray the Fluid Film, but you will not reach many of the areas that REALLY need it.
Oh ......be assured also, that when YOU are done, YOU absolutely will not rust!
   / Anyone out plowin? #149
Yes.....I have used it!
I also purchased my very own high dollar ARO/Bolair professional application equipment.
I realize that few folks would ever spend the money necessary for professional application equipment.
A homeowner can do a superficial job with several different products.
It takes a full day to do a professional job, and professional equipment is necessary to do a professional.
A little spray gun with a little hose, is just enough to make some feel that they are doing a good job.
The "ton of youtube video's" that you reference do not show what is being missed.
Perhaps we have a terminology difference here though.
To a certain extent your method WILL work for "undercoating".
I am talking about RUSTPROOFING the car!
   / Anyone out plowin? #150
whatever floats your boat buddy, I have used the graco sprayers, there is no considerable difference between them and the one in the kit. the kit from fluid film is more then adequate. but you seem to have your mind made up. I've been spraying for years, the kit works thats all you need to know.
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
2006 Wells Cargo 16ft T/A Enclosed Cargo Trailer (A55973)
2006 Wells Cargo...
JOHN DEERE 7930 MFWD TRACTOR (A52708)
JOHN DEERE 7930...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
