Anyone need Ford 1200 4x4 parts ?
   / Anyone need Ford 1200 4x4 parts ? #1
joes_427_vette
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
I have access to a nice Ford 1200 other than the fact the engine needs a crankshaft. Nice factory loader, rear axle, front drive axle, wheels, sheet metal, transmission, 3 point. Would take offer on the complete unit.
   / Anyone need Ford 1200 4x4 parts ? #2
Just curious if you or anyone else considered to work the crankshaft by prep and re weld of the Crankshaft journal along with grinding it down to spec. of course this is a machine shop type of a work rather than shade tree mechanic. A lot of short or long re-manufactured block use reground crankshaft. can't see what can go wrong with the counter weights.
JC,
   / Anyone need Ford 1200 4x4 parts ? #3
There was a guy on here some time back with a Ford tractor and a broken crank. He talked of bolting it back together. I think it didn't work in the end. Same tractor perhaps?
   / Anyone need Ford 1200 4x4 parts ? #4
Found the previous broken crank saga here:
Original
Update
End
Was this the same tractor or is that a common problem for that model?
   / Anyone need Ford 1200 4x4 parts ? #5
Hello,
Maybe intrested in the Ford 1200 parts tractor. I have a Ford 1100 that if the parts will interchange I would be intrested.
Can you contact me vial email at climartin@aol.com
Thank you,
Tom
   / Anyone need Ford 1200 4x4 parts ? #6
Joe,
I know this is an old post, but do you still have access to the 1200 parts? I need front wheels for my 1200.
Chuck
   / Anyone need Ford 1200 4x4 parts ? #7
I need the right-side pinon shaft drive gear and primary gear. Would you be willing to sell just these parts? If so, how much$$ ? If not then do you still have the tractor and would you be willing to sell it?
Thanks,
Steevo
   / Anyone need Ford 1200 4x4 parts ? #9
Hello, do you by any chance have any of this machine left?
Thanks
   / Anyone need Ford 1200 4x4 parts ? #10
I have a Ford 1100 4x4 and a front differential in a cardboard box that needs a pinon gear, and maybe a bearing or two. Does anybody have a full diff or parts they can part with for a reasonable price? Thxs.
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
