Anyone mowing lawn using mmm on mid or large frame
   / Anyone mowing lawn using mmm on mid or large frame #11
</font><font color="blue" class="small">( How high does the MMM pick up off the ground? )</font>
Going by memory it lifts about 6"-8". I'm not sure if you mean lifting it high for mowing high grass or for ground clearance when doing other things. For tall grass it's plenty. For ground clearance you can high-center the tractor if you start having too much fun in the dirt. /forums/images/graemlins/blush.gif
The attached pic is my 4400 with the deck nearly fully lifted. The reason it's "nearly" lifted is that I generally lower it a bit from full height to keep it from clunking against the top stops while driving on bumpy ground.
   / Anyone mowing lawn using mmm on mid or large frame #13
We have a 4120 with front end loader and 440lbs of rear wheel weights. It makes pretty good impresions in the grass when it's damp even with the R4 tires.
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
Quick Attach Pallet Forks (A47384)
Quick Attach...
1975 Trailmobile Enclosed Van Trailer (A52128)
1975 Trailmobile...
