anyone made a pto winch on 3 point hitch
   / anyone made a pto winch on 3 point hitch #1
pabelote
nc
fords
snake wood on ocassion an even with 4x4 i get mired up. was
wonderin if someone might have plans to make one
just found the search button an found info thanks
   / anyone made a pto winch on 3 point hitch #3
My buddy is in the middle of making a three pt. pto logging winch we should be putting the finishing touches on this weekend then I will have some pictures posted
   / anyone made a pto winch on 3 point hitch #4
Look on page 2 of this forum under" your opinion please" I have posted some pic of the one that I just finished. Since the photo I have added a grader blade at the base. It works great. ways ahead of a PTO winch.
   / anyone made a pto winch on 3 point hitch #5
Powerstroke2000
I will be very interested in seeing those pic's. Lots of good talent out there.
   / anyone made a pto winch on 3 point hitch #6
Deerlope
I seen your picture and I can tell you it is not going to look that good. Everything was made from scrap even the winch, the only thing he bought was some bearings and the cable the rest was in his scrap yard even the pto and the blade
   / anyone made a pto winch on 3 point hitch #7
It does not matter what or how good it looks just as long as he is happy with it and it does what he wants it to.
   / anyone made a pto winch on 3 point hitch #8
back in the early 80's I built pto winches for tractors from the 16hp beaver to the 33hp yanmar and everything in between. I built an 8000lb unit and also a 12000lb. They had a blade on the back for pushing and clearing brush and a fairlead to keep the line on the drum as well as a surrounding flange that would keep the line from coming over the flange on the winch and wrapping up on the drum axle. With pto winches be sure that you have a left hand rutn on the input shaft to make the line spool over the top when coming in. On winches that are upright models, the line must come in on the bottom of the winch. I have them scattered from oregon to alaska without any complaints and have thought about getting back into fabrication of them.
In my opinion the pto is the way to go as the hyd will not give much line speed, although it is a safer winch as you can set the relief valve on the hyd spool delegated to the winch to prevent line breakage.
As to the finn and austrian winches, they are nice, but, with the line being pulled in from so high initially, they are hard on the lower links of your tractor. As the line pulls it pulls bak on the top ling trying to compress the bottom link as the tractor is pulled bakcwards. I have seen some of the smaller units with factory angled lower links collapsed by the winch.
I do have a winch permanently mounted in my loader, which is hyd and I use it more that I can tell you, I think anyone other than the lightest of hobbists should consider one. I also have a pto unit that I use for logging off the 3pt that I made. It is a used model 9 gearmatic from a log skidder and I can outlog my 350JD crawler with it.
Here is a pic of them both. Note the lack of a good fairlead on the front winch, I would recommend one, I just need to get in gear and make it.
   / anyone made a pto winch on 3 point hitch #9
no. 2
   / anyone made a pto winch on 3 point hitch #10
this is a pic of my pic book hope you can make it out,
by the way, the tree in the background that is leaning, it is about 10 inches at the base. I habe one block on it for direction of fall and that is a 33hp yanmar with 12000lb winch. I pulled it completely out of the ground and only the blade to keep the tractor in place
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
