Anyone know where I can get weight for my DK-50? I want to get a trailer...
   / Anyone know where I can get weight for my DK-50? I want to get a trailer... #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Hello all, Been a long time since I was here asking questions so I thought I'd return.
I just got a new to me truck and I'm planning for a trailer to haul my DK-50.
So I have a DK-50, front loader, bucket, and loaded rear tires (RV antifreeze in one, and water & kerosene I think in the other - Long story about how that happened so we'll skip it).
I found a reference saying the tractor itself was just under 4,000lbs, and the loader was about 1,500 LBS.
When registering my 2010 F350 they gave me a GCVW of 15,000 max, and an empty weight of 6,200.
I'd like to be accurate and plan accordingly so I can be law abiding.
Thank you in advance for any assistance.
Be well,
David
   / Anyone know where I can get weight for my DK-50? I want to get a trailer... #2
Be well,
David
You need a 10K tandem axle trailer, but for an F-350 I would consider a 12K trailer.
If you are not hauling for commercial/business reasons a 12K build rated trailer should be legal in your state.
Makes sense.
My issue is I'm trying to figure out actual weights so I know what is the max I can load, and I can't get the tractor weighed until AFTER I get it on a trailer...
I've don some looking, but the web has the current version tractor and loader, not my old one...
David
   / Anyone know where I can get weight for my DK-50? I want to get a trailer... #4
According to tractordata, just the tractor would be 3,902 assuming ROPS on a 2007+ model DK50SE
TractorData.com Kioti DK5SE tractor dimensions information
Do you know the model of the loader?
Estimating weight of loaded tires to add 503lbs per tire if they are 14.9x24/8 like tractordata says. Obviously not perfect as they aren't filled with rimguard but this should give you a high number.
Thank You! Great Website!
I assume the 2nd weight listed is for full of all the liquids (fuel, oil, hyd fluid, water) so I used 4354 + 1284 +1006 and got 6644 lbs. which leaves me up to 2156 for trailer weight!
WOOT!
Thanks,
David
John Deere 693 Corn Head (A50514)
John Deere 693...
Vermeer SC802 (A50322)
2018 ford explorer (A50324)
2018 ford explorer...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
