Anyone know where I can get weight for my DK-50? I want to get a trailer...
   / Anyone know where I can get weight for my DK-50? I want to get a trailer... #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Hello all, Been a long time since I was here asking questions so I thought I'd return.
I just got a new to me truck and I'm planning for a trailer to haul my DK-50.
So I have a DK-50, front loader, bucket, and loaded rear tires (RV antifreeze in one, and water & kerosene I think in the other - Long story about how that happened so we'll skip it).
I found a reference saying the tractor itself was just under 4,000lbs, and the loader was about 1,500 LBS.
When registering my 2010 F350 they gave me a GCVW of 15,000 max, and an empty weight of 6,200.
I'd like to be accurate and plan accordingly so I can be law abiding.
Thank you in advance for any assistance.
Be well,
David
   / Anyone know where I can get weight for my DK-50? I want to get a trailer... #2
Be well,
David
You need a 10K tandem axle trailer, but for an F-350 I would consider a 12K trailer.
If you are not hauling for commercial/business reasons a 12K build rated trailer should be legal in your state.
Makes sense.
My issue is I'm trying to figure out actual weights so I know what is the max I can load, and I can't get the tractor weighed until AFTER I get it on a trailer...
I've don some looking, but the web has the current version tractor and loader, not my old one...
David
   / Anyone know where I can get weight for my DK-50? I want to get a trailer... #4
According to tractordata, just the tractor would be 3,902 assuming ROPS on a 2007+ model DK50SE
TractorData.com Kioti DK5SE tractor dimensions information
Do you know the model of the loader?
Estimating weight of loaded tires to add 503lbs per tire if they are 14.9x24/8 like tractordata says. Obviously not perfect as they aren't filled with rimguard but this should give you a high number.
Thank You! Great Website!
I assume the 2nd weight listed is for full of all the liquids (fuel, oil, hyd fluid, water) so I used 4354 + 1284 +1006 and got 6644 lbs. which leaves me up to 2156 for trailer weight!
WOOT!
Thanks,
David
UNUSED FUTURE FT-PDQ 40" LAND LEVELER (A57193)
UNUSED FUTURE...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A55853)
2025 Nationcraft...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
