Anyone know where I can Find a carb gasket set for Horse1 tiller 6 hp.
   / Anyone know where I can Find a carb gasket set for Horse1 tiller 6 hp. #1
arboristjames
Port Angeles, Wa..
JD 650,Horse1 tiller
Hi All, I was just given this machine for free after it had been sitting in a barn for 25yrs. After I got all the chicken s**t off it I pulled the spark plug put some 2 cycle gas in the cylinder to soak overnight, slowly turned the motor over the next day, put a little fuel in the tank and it fired but would not run. My conclusion is that the carb is loaded with varnish and in need of re-building, the problem is "where can I find all the gaskets I need"??? Thanks in advance for any help available.
   / Anyone know where I can Find a carb gasket set for Horse1 tiller 6 hp. #2
Might help if you told us what engine is installed.
Make, model HP et.
Thanks for the lightning response!! 6 hp tecumseh, mid 70's, James.
   / Anyone know where I can Find a carb gasket set for Horse1 tiller 6 hp. #4
Try to find the numbers on the motor,lots of places to look for parts.If it is an H60 or HH60,look on Ebay. Try "HH60 Carb rebuild"
Parts Tree,or Superxpower are good places to look.
   / Anyone know where I can Find a carb gasket set for Horse1 tiller 6 hp. #6
In a pinch you can always cut one from cardboard or paper.
When stuck I make mine from light cardboard and rub grease into the finished gasket.
Also depending on the application liquid gasket (basically silicone in a tube) works fine.
On exhausts you then need heat resistant materials, but elsewhere there are all sorts of alternate options.
For 6 hp tecumseh, you will find kits at any small engine repair facility as it may just be the most common engine ever built.
As a carb cleaner I have used jiffy oven cleaner in spray can with success. Just be sure to thoroughly rinse with warm/hot water once cleaned as that stuff is very corrosive.
   / Anyone know where I can Find a carb gasket set for Horse1 tiller 6 hp. #7
If you can find the model number on the engine. google to the tecumseh site and look up your model for the right parts. Or gasket paper and a can of the " right stuff " gasket material
Hi all, thanks for all the responses to my request, I a impressed!!. I think I may have located the parts at "Parts tree". Will keep you posted, James.
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
12in Backhoe Bucket (A53472)
12in Backhoe...
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
