Anyone know the thread size of Kubota grease fittings?
   / Anyone know the thread size of Kubota grease fittings? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Kubota doesn't list the thread size and I don't feel like ordering one for $2.50. This would be for front axle fittings. Surely it must be some standard metric size?
I know, or think I know that most loader fittings are 1/4-28.
   / Anyone know the thread size of Kubota grease fittings? #2
I just looked at my parts manual and it only gives a part#. Buy one of the multipacks from tractor supply and use process of elimination. Always worked for me with any grease fitting.
   / Anyone know the thread size of Kubota grease fittings? #3
Probably a metric bolt thread. My BX axle has no zerks. Haven't had to replace any on the implements yet. Surprised I haven't broken one on the BH or FEL. I have multi packs of SAE, Metric, and IPS types. They could also be the drive in type
   / Anyone know the thread size of Kubota grease fittings? #4
Get the 100 pack of assorted metric sizes from Harbor Freight, Tractor Supply or Amazon. They are only $10 or so & you'll never run out of spares in all the sizes or angles.
   / Anyone know the thread size of Kubota grease fittings? #5
The typical metric grease fitting is M6
   / Anyone know the thread size of Kubota grease fittings? #6
I'm familiar with your dilemma. I also had one break. So - I simply order one of those assorted packs in both the metric and SAE thread types. NEITHER one worked - nothing fit exactly right.
I finally just took my broken zerk by the dealer, picked up a $0.35 replacement and problem solved. My only relief in this blunder was that I have 200 zerks on hand for most applications, except Kubota tractors.
   / Anyone know the thread size of Kubota grease fittings? #8
M 6.0 x 1.0
   / Anyone know the thread size of Kubota grease fittings? #9
Pretty much the right approach ! No matter where you look up the "correct" size it may not match the actual threads. Often they SEEM to match until you get in 2 or 3 turns and they bind or will go in no further, thus telling you you are using the wrong size. Buying the "100 assorted" is lesser of evils but creates a fresh problem -- now you have to sort through most of them trying to find a match. Such a pain. The industry SHOULD standardize on 2 or 3 sizes and abolish the rest. We won't live that long even if they decided to do it.
   / Anyone know the thread size of Kubota grease fittings? #10
Look on the bright side, at least the business end of the zerks are all the same!
2016 Volkswagen Jetta Sedan (A42744)
2016 Volkswagen...
Aqua Sculpt Reviews 2025: The Latest in Body Contouring
Aqua Sculpt...
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A44391)
2006 Ford Explorer...
72" Skid Steer Sweeper JCT Standard Flow Sweeper (A42203)
72" Skid Steer...
12V Diesel Pump Meter And 50 Ft Hose (A44572)
12V Diesel Pump...
2010 TEXMEX CONTAINMENT TRAILER (A45046)
2010 TEXMEX...
