Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD?
   / Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD? #1
JRP3
Iseki TL-2101FD
Trying to find what pressure the hydraulic system is supposed to run at for this tractor. I have a log splitter plumbed into the power beyond port from the Koyker 155 loader on the tractor and it's not performing as I expected.
I put a gauge on it and get a max of 2000 psi. Don't know if that's what it's supposed to run at or not.
   / Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD? #3
Mines a different model, however mine too is very weak (2000psi), just need time to pull the pump off to see what sort of drive it has (apparently there's two types) in order to replace it.
As far as I know, there's no pressure relief valve in the pump.
   / Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD? #4
@Marcle: i sent you a pm or email with a question about your double wheels, but never got an answer.
Any chance you can send me pm with a description on how you did this?
Last weekend i almost sided for the second time, i would really like to solve my problem. Hope you can help me.
Looking at the data for a similar vintage and sized Kubota L245 it also shows 2000 PSI system pressure, at 3.7 GPM. TractorData.com Kubota L245 tractor information Here's an Iseki TX2160 showing 1850 PSI at 2.7 GPM TractorData.com Iseki TX216 tractor information
Has to be a pressure relief valve somewhere in the system.
   / Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD? #7
My pressure was before the PRV as I rerouted my pipework to take advantage of maximum pressure, but did not gain any additional pressure.
Is there any sort of PRV in the pump?
Don't know, I just found those pics, they aren't mine.
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
