Anyone know how to get rid of a pond algae bloom?
   / Anyone know how to get rid of a pond algae bloom?
Ok great. Thanks guys
   / Anyone know how to get rid of a pond algae bloom? #12
Another way to stop the growth is for the water to be deeper,, keeping the sunlight from getting to the bottom,,
You said the pond had leaks, is it too shallow now?
It’s actually 3-7 ft on shallow end but most of the pond drops off deep fast due to being made from a natural run off which made a type of deep valley gorge. It was built up with high wall of dirt making a dam on its lower side. The pond is currently right at 20ft on the lower side. Averages 10-15 on the upper side though. Only the first 10 yards of the pond is 3-7 feet. If there wasn’t any leaks it would be another 10-15ft deep based on where the drain is located.
   / Anyone know how to get rid of a pond algae bloom? #14
If your dam is leaking, I'd take a good look at what is down stream. A slow leak can turn into a trickle, then a stream, and tear out your dam in short order. You may be OK if the pond generally stays below the leak level now, but what happens if you get a really we spring or a couple of major back to back storms? Once the level gets high enough to start the leak flowing, it can erode thing down pretty quickly.
Hard to say what the risk is without seeing your set-up, but worth taking a close look at. Hopefully you or a neighbor don't have anything valuable in the potential flood zone
Yeah good point. I may walk on backside of dam to see if I can find where it’s at. It must be in dam as it gets so low then stops. Never goes lower than that point.
   / Anyone know how to get rid of a pond algae bloom? #16
If you don't see anything in the dam, it is possible that the sides of the pond are just leaking out into the ground. That's generally not a risk-filled situation, but it can be annoying,
Ok thanks I’ll do some looking this weekend
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
1999 Caterpillar CS-433C 66in. Vibratory Dirt Compactor Roller (A55787)
1999 Caterpillar...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2018 Nissan Sentra Sedan (A55758)
2018 Nissan Sentra...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
Cat TH407C Telehandler (A53472)
Cat TH407C...
