Anyone know electric motors?????
   / Anyone know electric motors????? #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
We removed the cupola fan in horse stable. It has a 3ft square wood mounting frame fan is attached to so we made a 36.25" square box out of 2"×10" lumber.
When first installed we tested it with extension cord, black & white wires poked into plug. It worked perfectly, running over an hour, even cycled on & off.
Then I ran 12-2 wire in plastic conduit up to it, tried, it never ran & tiny whiff of smoke.
I re-tried extension cord test, motor never ran. Blade spins free. Fan mounted in wood so no metal anywhere close.
So fan removed. I removed GE motor. Here is what I measured:
Starting cap 7.5ufd, measures 7.45ufd
Black to white 4.6 ohms
Black to green 1.9 ohms
White to green 6.5 ohms
Starting capacitor leads 87.9 ohms
As you see in pictures, with motor apart there are three windings...heavy copper, a small gauge copper and small gauge dark green. They wrapped string around, string burned in two places I'm pointing to.
Just for fun I put motor together, jumped it two wires black & white and (drum roll)...it ran!!!???!!!
Now I'm completely baffled, it makes absolutely no sense. I know basically nothing about electric motors, but the green (ground) wire measuring like it does to neutral or hot I don't understand. I thought that was ground for metal motor case?
Any assistance, thanks in advance...
   / Anyone know electric motors????? #2
it has a short to ground. When you tested it (white and black) there was no ground so no problem. However, it was dangerous, you could have been hurt f you touched it and ground at the same time.
When you wired it properly, you heavy current to ground.
It is defective, don't use it.
Ken
Ken
Wow...thanks! I thought ground green wire to hot or neutral low resistance sounded weird.
It's 24ft in air so nothing will touch it but I won't use it. Thanks so much. I'll take measurements...hopefully I can find a motor & trash can this one.
   / Anyone know electric motors????? #4
Green (or bare wire in the Romex cable) is ground for the outside cover, the motor frame etc. On a 110v device, black is hot (+110) and white is neutral (the return circuit for the black 110.)
A DC ohm meter will not give you an accurate measurement of the AC impedance because you are measuring a coil and it provides more than just DC resistance.
You said you were using 12-2 wire. I assume that is 12-2 with ground.
Yes...3 wire. So should I:
Replace just the motor. I have two, the squirrel cage similar one & I have two industrial pedestal fans which same diameter blade, but 1/2hp bigger motor (2 speed)...they ohm out fine, work well, I'd just use one's motor, it will physically fit.
Or just buy another fan (about $400-$500).
Thanks...(I'm retired, plenty of free time)
Forgot pictures:
   / Anyone know electric motors????? #7
All that wire in the windings is “coated.” The burned area has this coating compromised. It likely does not touch wire to wire when cold or not vibrating. But when things warm up and/or vibrate then the compromised coating lets copper to copper in the winding touch. Maybe even touch the steel core slightly.
As others said, It’s toast.
   / Anyone know electric motors????? #8
There shouldn't be continuity between green and either wire (much less both) tells you windings are shorted to ground. Not dead zero resistance short but shorted non the less.
   / Anyone know electric motors????? #9
Sorry that it burned up. As @Ken45101 put it so well, it is toast. I doubt that it was anything that you did; it just wasn't made properly.
You might just look for your motor replacement online, or for something similar. E.g. Surpluscenter.com;
All the best,
Peter
   / Anyone know electric motors????? #10
You can probably fit either of the motors you have. They are both 48 frames. Does the old motor have a name plate?
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2021 MACDON C3812 LOT IDENTIFIER 34 (A53084)
2021 MACDON C3812...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
