Anyone have U5030C of XU5065CPS?
   / Anyone have U5030C of XU5065CPS? #11
I've had a U5020C with an LL5100 loader for almost a year now. The pallet pictures contains 36 - 50lb pails of cement plus the forks and pallet itself. It lifts them with no problem at idle and with no ballast other than the loaded rear tires. She does get a little light when at full height, but manageable. I plow snow with the FEL (7ft blade), grade drivewys and such. It does everything I need and more. I do a lot of road running in the winter plowing local driveways and found she bogged a little in high (16th) gear, so I turned up the engine to ~55hp - 57hp and she works great now with no boggin at all! I had originally wanted the U5030C but the dealer talked me into the U5020C becuase it was less money and would do everything I wanted and he was right.
I
Hey thanks much for the reply! That's what I was looking for!
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56435)
2017 Rogator...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
