Anyone have the top & tilt field kit?
   / Anyone have the top & tilt field kit? #11
What do you mean straight up and down?
I've got it on my 3720 and it does the same thing. It's normal. I've really enjoyed the TNT even though it was expensive.
yeah i figured. I just took it off now for the winter since it wont have anything on it besides the weight box.
Its funny, when i got the tractor it didnt fit into my one bigger garage :( I had to let a LOT of air out of the tires in back to get it to clear, and it was still close.
I then chopped about 2" out of the top beam of the old barn garage, will put a 9 or 10' garage door on eventually, and then the same day, i added the 1500~lb rear cement weight ballast box right? I let just a tad of air out of the tires, hoping it will clear now, its got 3"!
Just the compression of the back tires from the weight box would have probably lowered the back the couple inches, now i have a couple to spare at least ! lol
SAFTEY TIP: LOWER ALL RAISED EQUIPMENT.
yeah i always do, but you can lower your 3pt hitch fully, and THEN have to switch over to the diverter to lower the pistons of the two hydraulics of the top and tilt seperately. This not only just tilts the weight box back way too much but will also probably bend the weight box because its now VERY crooked from lift arm to lift arm, the idea is that you want that to stay flat in storage not crooked.
YALE STRAIGHTMAST FORKLIFT (A51406)
YALE STRAIGHTMAST...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A54865)
2004 Ranger 195 VX...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
