This is my experience with the MAX 26XL mulching kit: I bought the mulching kit for my 2016 26 XL towards the end of the 2017 season primarily to mulch leaves, but had thoughts of leaving it installed full time. First thing I noticed when I got the kit was it only came with a steel discharge plug and three mulching blades. If you go to the Mahindra parts website and look up the mulching kit for a MAX 26XL it will show the plug, a mid deck baffled, and three mulching blades. It was a wet season last year so I experienced the clumping issue that NE Snowblower mentioned. I contacted my dealer and pointed out the mid deck baffled discrepancy and was assured that I received the correct and most up to date kit. My thought is the mid deck baffled would help stop all of the grass clipping from being forced to the discharge side (clumping). To help fix the clumping issue I ended up removing the the ~1/4" blade spacer and installing the original blade and then the mulching blade in a X pattern for a total of 6 blades. The 6 blade setup helped to alleviate the clumping issue and just destroys the leaves. Just for the record, I know I was mowing wet grass and was probably taking to much of a cut, but I work full time and only get to mow on the weekends regardless of how much the grass grows during the week. In concussion, I can't really recommend the mulching kit for full time use unless you are cutting ~1/4" of dry grass or you like mowing at 2 mph. If you end up getting the mulching kit please post what components it came with as I still feel I was sold an out dated kit, or maybe an updated cheapened up kit (who knows). I feel bad, this is my first post on here and it is negative towards Mahindra, so just let me say I love my MAX 26XL and the cut I get with the 60" MMM (without the mulch kit).
