smfcpacfp
Veteran Member
- Joined
- Nov 21, 2007
- Messages
- 1,346
- Tractor
- Kubota B3030HSDC
cell foam insulation. It appears to give you the R value per inch (around 7) of any insulation.
Can it be applied directly to the metal siding of a pole building (which appears to be the case)?
Can it be applied to a thickness of 5"? It appears that you might have to do it in multiple layers.
The pole building I recently completed is going to have a 15' by 24' workshop area which is pretty small, but adequate. I was going to use propane heat, but given how small the area is, a contractor friend of mine suggested baseboard electric heat which would be simpler to install and involve no cutting or propane storage, etc. I figured if I insulated the heck out it, (R - 35 in the walls and 3 feet or so of blown in insulation in the ceiling) it might not be that costly to heat during the portion of the day that I would use it. I couldn't imagine using it more than 20 hours a week during our 6 months of heating.
I do live in an extremely cold part of the country with 40 plus sub zero days being the norm.
