Anyone have a MechMaxx 3-pt stump grinder?
   / Anyone have a MechMaxx 3-pt stump grinder? #21
Congratulations! That steel cross bracing on the side of the "crate" was bent just enough on my Woodland Mills unit to rub off a spot of paint on the back side :mad:. Otherwise, I have been happy with the WM version so far.
I have already made several items from the steel crate: put casters on the bottom for a dolly for the grinder and some of the flat bar for other projects.
Be sure to follow the directions and start on the right side of the stump (looking forward).
Appreciate the info, I am considering a pats quick hitch system, but I am not sure if it will fit yet when my backhoe is attached. So i need to do some measuring. once that is installed I will start the process of getting this installed, once i get the struts done on my truck (always something)
   / Anyone have a MechMaxx 3-pt stump grinder? #22
I have a JD quick hitch and the drive shaft fits on that without trimming.
   / Anyone have a MechMaxx 3-pt stump grinder? #23
yea the pto and drive shaft is all new to me, its impressively heavy with the slip clutch, i was curious if I was going to need a pto extender, sounds like I may not.
   / Anyone have a MechMaxx 3-pt stump grinder? #24
teeth expected monday
   / Anyone have a MechMaxx 3-pt stump grinder? #25
Teeth delivered without issue.
   / Anyone have a MechMaxx 3-pt stump grinder? #26
I have been wondering about it MechMaxx company that has been popping up in some ads. I think they have a logging winch if I am not mistaken.
   / Anyone have a MechMaxx 3-pt stump grinder? #27
they have tons of stuff. and they actually respond to email, albeit about 3 am, other then them taking longer to get it to me. There was 0 issue with the delivery. Normal lift gate truck, and UPS delivered the teeth.
   / Anyone have a MechMaxx 3-pt stump grinder? #28
It's interesting, the website is VERY reminiscent of the Harbor Freight website. You're right, they do have a lot of stuff.
   / Anyone have a MechMaxx 3-pt stump grinder? #29
It's just so weird that they seemed to come out of nowhere just a couple of months ago. Has the company actually been around longer, but I just never heard of them?
   / Anyone have a MechMaxx 3-pt stump grinder? #30
No idea but even the teeth have their brand name on them in a box.
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Service Truck (A55973)
2015 Ford F-350...
HARDEE SH-360-CO 5' DITCH BANK CUTTER (A52708)
HARDEE SH-360-CO...
4" X 4" WATER PUMP W/ HONDA ENG (A52708)
4" X 4" WATER PUMP...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
Freighliner Tender Truck (A56436)
Freighliner Tender...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
