Anyone had this problem?
   / Anyone had this problem? #1
MLinOleMiss
Collins, MS
Mahindra 4110
Changed the fuel filter on my 4110 this week and the ring/nut that holds the bowl in place broke in half when I tried to put it back on. Went to the dealership and got a new one and it absolutely will not fit. I even took the entire assembly off of the tractor to make sure that I had everything lined up and level and it seems about a millimeter or so too small.
   / Anyone had this problem? #2
Yes, the threads in the old nut had disintegrated on mine so I ordered a new one last year. The new one was a real bugger to get started, almost didn't get it on far enough to seal the bowl. The threads on the housing were OK and I used some anti-seize on the nut for lubrication but I doubt I'll be able to remove it without damage to something. When the filter needs changing next time I think I'm going to do away with this setup and put some other filter inline there. On that old nut it wasn't just worn-out or cross-threaded, the metal actually crumbled away and there were just big gaps in the threads. I've only had the bowl off 3 or 4 times since the tractor was new, once to replace the plastic bowl a few years ago as it started developing cracks, the other times to change the filter. That nut is rather pricey too ...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2014 Ford Escape SUV (A50324)
2014 Ford Escape...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
2010 John Deere 6100D (A50120)
2010 John Deere...
Landoll Hauloll (A52748)
Landoll Hauloll...
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
