anyone got a similiar set up?
/ anyone got a similiar set up? #1
DMG Tractor
electric /hydraulic switch on your loader stick for your true 3rd loader function as well as a separate independant rear remote. on your compact tractor?......
Just bought a 4105 supposed to be equipped as follows:
Cruise control
Block heater
300 cx loader, 61 inch matls bucket and a skid steer carrier adapter
True third loader function with electric/hydrualic switch
1 rear remote (possible two as sales was almost sure the new ones were coming with one rear remote as standard equip.)
A 72 inch frontier box blade.
was supposed to take delivery on the 23rd of June...
Tractor arrived at dealer a few days late ( i'm thinking no big deal), however, they sent the wrong loader mounts ( they sent the 3000 series mounts and not the ones for the 4105) NO cruise, NO rear remotes, NO electric/hydrualic switch, No box blade and i forgot to check if there was a block heater. they did however send the skid steer adapter and the extra hoses for the thrid function loader hydraulics. I suspect it'll be a couple more weeks before i get my tractor and the dealer is trying to push my third loader function be run from a rear remote with ( i assume ) a detent valve or something. I'm suspect they want to do that way because they might have configured or ordered it wrong with their software. Anyway I am not accepting that as everyone was clear on what features i wanted my tractor to have. I've already signed the dotted line and they'll have to do what ever takes to make it right.... would you not agree? this has been somewhat frustrating for sure.
Signed "wondering if Orange would have been easier Dave"
/ anyone got a similiar set up? #2
I understand your concerns.... However, don't go jumping off of any tall curbs just yet! Many optional equipment features are "FIELD INSTALLED"! That is, your dealer will receive the attachments and his shop crew will do the installations.
Cruise control on the 4000 series is a switch mounted in the fender well that plugs into an existing wiring harness - lengthy and difficult - likely 15 minutes shop time! :D
The 3rd function on your FEL might well be optioned from the 3rd rear SCV with an electric diverter that will be controlled from the joystick. The toggle switch (on joystick) will divert hyd pressure to the loader when needed or to the rear SCV - back and forth. Very clean setup - and not that a difficult challange for your dealer - IMO.
Long story - short - give your dealer the benefit of the doubt.
Everything you've listed as options is doable by your local guys; if they get the right parts!!
AKfish
Well hopefully you are right. As far as the hydraulic setup goes that makes kinda sense to me...however its not really what they were suggesting .. the sales guy was suggesting that i would have physically make the hose connection at the back in order to use the 3rd loader function... and disconnect it to hook up to a rear implement hydraulic... maybe to shop guy has a clear understanding its ust not the feeling i am getting
/ anyone got a similiar set up? #4
DMG,
Now is the time to go sit down with your dealer. There are several different possibile outcomes with the info you provided. The most common electric over hytraulic 3rd function uses the curl function of the bucket. This means the electric diverter is located where the 4 lines going to the loader hook to the tractor. I know on some of the new tractors there is an electric rear remote option(this sounds like what your dealer has in mind for you), honestly I don't this is as good for the 3rd function up on the loader, you have to run lines from the rear of the tractor all the way up the loader, the longer the lines the higher the likelyhood of catching 1 at some point, also it would require a disconection of the 3rd function to the front to use the remote for the rear as the sales guy indicated. All that said, talking to the dealer now before any work is done will help to make sure you end up with exactly what you want, which is what they want(happy customer).
I hope this helps,
Todd
/ anyone got a similiar set up? #5
By all means, talk with your dealer! It's much better to get a complete picture of the EXACT configuration BEFORE it has been installed! :thumbsup:
If you have a choice between a diverter using the curl function on your loader versus tapping into the rear SCV - go with the rear SCV- IMO!!
That way, you won't have the bothersome and oftentimes awkward chore of switching on/off so you can curl and grab at the same time! Using my loader grapple with brush and limbs, etc. I can only imagine how clumsy that might be trying to grab at the same time as you're trying to curl the whole wad back towards the loader frame.
AKfish
/ anyone got a similiar set up? #6
AKFish,
I respectfully disagree with your analysis. You said it would be awkward to curl and grab at the same time with the diverter on the curl circuit.
The 2 possibilities the OP has listed are a true rear SCV or electric diverter for the rear outlet. For the true rear SCV he would have to take his hand from the steering wheel to operate the handle for the rear scv, providing the grab, while his other hand is on the loader joystick, for the curl. In the case of an electric diverter for the rear outlet he still has to use the switch between 2 of the functions.
As I said earlier I have the diverter on the curl function and having moved many tons of large round and large square bales I have never felt handicapped in any way. For me keeping my hand in one place while being able to switch between the grapple and the curl works the best. I don't like the idea of having to reach down for a different lever to grab or release a 1500# bale of hay.
Different things work for different folks thats the beauty of these forums you can get a lot of opinions from people who already have what you are looking at.
Have a good day.
Todd
/ anyone got a similiar set up? #7
Deere came out with a 110TLB style handle and control for some of the CUT line this year. It adds a EH valve for 3rd function loaders. Perhaps this is what the tractor was supposed to come with. I thought that was a factory add though.
/ anyone got a similiar set up? #8
I have the electric diverter plus the 3rd SCV on my 3720. Also the line set for teh grapple.
I woould suggest using the 3rd SVC for any optional equip. Right now I have my 3rd scv hooked to my hydraulic angle on my Harley rake so I used one of the diverted port sets for the hydraulic top link. You don't know how many times I have gone to nudge the loader and moved the top link because I forgot to flip the switch back...
Most if not all of these options were ordered with tractor and installed by dealer.
P.S. Orange would have certainly been easier as I don't think you can even get electric diverters of half teh options that you can get with Greene
/ anyone got a similiar set up? #9
Maybe there's some confusion... for both of us!
If he has the 3rd rear-mounted SCV - in your words - a "true rear SCV". AND then installs an electric diverter - which utilizes the hyd circuit of the 3rd rear-mounted SCV - by diverting that hyd flow to the 3rd SCV FRONT loader function; grapple, etc. when required; he won't have to operate a "handle" or even toggle the switch more than once. (Unless he has a rear mounted hyd cylinder connected to the rear SCV.)
Never have to leave the steering wheel, never have to drop your hand from the joystick - AND - he'd never have to toggle between curl and grapple or back and forth numerous times between curl and grapple while loading debris or bales.
Click - front grapple. Click - rear SCV. It's that easy. Curl always works; and you don't have to worry about whether the curl is gonna twist back or the grapple is gonna close. 'Cause if you're like me... I routinely would forget when the curl is on or the grapple is on! And in the heat of working a pile of tree limbs or a pod of square bales; I get curl when I wanted grapple!
AKfish
/ anyone got a similiar set up? #10
The diverter on my JD 110TLB switches the front 3 hydraulic functions - loader boom, curl, and grapple - to the rear 3 hydraulic functions - top, tilt, and equipment cylinder if used.
I know it's very easy to forget where/what the diverter function is currently on. That's exactly how I smashed my rear tail light/turn signal with a rear mounted disc mower! The rear cylinder lifted the mower in the air - too high - when I expected that the grapple would close! Wrong...
Another option is to work from the Power Beyond cirucuit and install open-center spool valves from that. Typically, that approach involves more hardware and can take up valueable real-estate at the rear of your tractor, etc.
AKfish
AKfish
YES AKfish.. the last part of your description is exactly how i want this to function ....click front grapple... click rear scv.... using a diverter controlled by the electric switch, i also specified that i wanted the loader control knob with the rocker style thumb buttons to control the grapple... I knew what i wanted to be able to do withthe machine just could not describe what the basic configuration had to be... Thank you very much! I feel i can now sit down with the dealer and we can all get on the same page.... once again thanks... lots of valuable info throughout this whole thread.. thanks people :)
Dave
/ anyone got a similiar set up? #12
I think it's better to run the 3rd function for the loader off the rear outlet. I have a 4 in 1 bucket and need to use the curl at the same time as the bucket close to pick things up. Yes I do take my hands off the stearing wheel but I am sitting still or just rocking back and forth licking stuff up. For my top and tilt I added another valve to the power beyond line with two more sets of outlets.
Dan
/ anyone got a similiar set up? #13
I think some are missing the point of the joystick arrangement. As AKfish eluded to the rocker switch on the fel joystick can control an electric over hydraulic valve and further its place on the tractor could be anywhere. It is more user freindly if it does not interrupt use of the curl circuit, so that these can both be used simultaneously. Using the selector switch to choose either the fel auxillary circuit or the rear outlet and the rocker switch to control the electric valves direction is the more ergonomic approach.
Why Deere doesn't offer a three spool diverter setup on the tractors similar to the 110tlb has always been my question. Having three front circuits and three rear circuits makes the 110 very useful and flexible. It should be available on a 4x20 tractor too.
/ anyone got a similiar set up? #14
AKfish,
You are right I used a poor descripton and it caused more confussion.
Dave,
I don't think what you are looking for is possible unless there is something new and different on the 2011 tractors.
Your loader joystick controls 2 valves the lift circuit and curl curcuit, if you use an electric diverter on one of those the joystick can control the 3rd function but you can only have 2 of the 3 functions available at a time. With a diverter on the curl you have lift and curl or lift and grapple.
If you have the true 3rd SCV on the rear it will have its own control lever. You can put an electric diverter on it to control both the 3rd function up front and a rear function. But you will have to use its control lever to regulate the flow thru the SCV, you will be able to use the 3rd function at the same time as either or both of the joystick functions if the hydraulics are up to it.
I agree a 3 spool valve would be the best idea but JD hasn't seen the light yet.
I hope this helps some.
I know having the loader be able to do three functions at once is possible there is an extra hydraulic circuit required and the loader joystick gets a new grip.. the grip is part of what deere calls electrohydraulic thrid function.. (you can get aftermarket versions too from everythingattachments.com for example... the part i don't understand is exactly how the tractors hydraulics are modified ( ie .. the plumbing) in order to make it work especially with have a set of service couplers on the back...maybe the third function is a dedicated scv and the rear remotes are a fourth.. i don't know.. I would be okay with the 3rd circuit being able to serve the thrid loader function and the the rear remote if there is a convienent way to switch between the two... ie a valve with manual level or another electric over hydraulic solenoid and valve.. the Canadian long weekend is over now.. and i'll be sitting down ( once again) with dealer this week to ensure that the machine gets configured as i need it... I have a feeling they will accomodate my needs.. ( cause its gonna plug up their little shop until it does.. lol)
/ anyone got a similiar set up? #16
Sounds like what he wanted/expected was a three function loader valve. Joystick operating boom and bucket, and electric switch in the joystick controling the third valve.
The third valve being part of the loader valve, NOT a rear SCV.
I don't know if this is an option for that series JD, but if not, the salesman should have known, and explained what he could get instead. I know you can get a 3 function loader valve on bigger series JDs.
Yes That is what i wanted turns out my machine doesn't have the neccessary 3 spool valve and the dealer should've have known, but they have admitted their error and going to install à power beyond kit and run s the electric/hydraulic set up using that hydraulic loop which should work fine. I hope. If so i'd be happy with that. I'll keep you posted.
U
/ anyone got a similiar set up? #18
Have you gotten this resolved? If so how did they do it. I have been shopping and comparing tractors for a few months now. Trying to decide which one is the right one. (too many options):confused2:. Anyway, I think the 4105 is what I will probably purchase. I would like the 3rd function for the loader as well. In the Deere online brochure it states "Electro-hydraulic SCV makes grapple work effortless.(4105)". I would assume there is a factory option that should do exactly what you want done.
So to answer you question, have you gotten this resolved the answer is " I think so".. the dealer told me this morning that the shop is doing up the final finishing touches and it should be floated over sometime this week. Make sure you explain clearly how you would like your third function to work.. depending on how you want it configured and what else you want on it changes what components must be purchased, you may need a power beyond kit if you want to have rear scv that are not intended for you third function up front for example... i'll say no more than this right now.. and offer the full debreifing upon delivery here if I'm happy with it.
